[Qgis-developer] Git repo available for testing
Martin Dobias
wonder.sk at gmail.com
Wed May 4 04:13:20 EDT 2011
On Tue, May 3, 2011 at 2:23 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi Martin (and others who need to merge changes over)
> On Mon, May 2, 2011 at 6:22 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> Then I have a question regarding merging stuff from other
>> repositories. For example customization we have done with Radim is
>> based on Sourcepole clone, Pirmin's globe work is also based on that
>> clone. Those are repositories with a different base, so I would expect
>> that merging will not work automatically. Anyone has some experience
>> with such use case?
> I wrote up a guide[1] on how to migrate your changesets into git from
> a 'foreign' repo. The process was quite easy for me, hopefully it will
> be for you too.
> [1] http://www.qgis.org/wiki/GitMigration
> If you want to preserve the history of each commit just omit the
> squash part of the process.
Thanks Tim, I will look into that soon.
Martin
