[Qgis-developer] Error_while _Compiling _Qgis_using _MSVC
Sunilrajkiran sunilraj.kiran at kcubeconsulting.com
Tue May 10 06:51:31 EDT 2011
Skipped content of type multipart/alternative-------------- next part --------------
# This is the CMakeCache file.
# For build in directory: c:/qgis_source/build
# It was generated by CMake: C:/Program Files/CMake 2.8/bin/cmake.exe
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Install bindings to global python directory? (might need root)
BINDINGS_GLOBAL_INSTALL:BOOL=OFF
//Path to a program.
BISON_EXECUTABLE:FILEPATH=C:/Program Files/GnuWin32/bin/bison.exe
//Semicolon separated list of supported configuration types, only
// supports Debug, Release, MinSizeRel, and RelWithDebInfo, anything
// else will be ignored.
CMAKE_CONFIGURATION_TYPES:STRING=Debug
//C++ compiler
CMAKE_CXX_COMPILER:FILEPATH=cl
//Flags used by the compiler during all build types.
CMAKE_CXX_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi /Ob0 /Od /RTC1
//Flags used by the compiler during release minsize builds.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
//Flags used by the compiler during release builds (/MD /Ob1 /Oi
// /Ot /Oy /Gs will produce slightly less optimized but smaller
// files).
CMAKE_CXX_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
//Flags used by the compiler during Release with Debug Info builds.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C++ applications.
CMAKE_CXX_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib '
//C compiler
CMAKE_C_COMPILER:FILEPATH=cl
CMAKE_C_FLAGS:STRING= /DWIN32 /D_WINDOWS /W3 /Zm1000
CMAKE_C_FLAGS_DEBUG:STRING=/D_DEBUG /MDd /Zi  /Ob0 /Od /RTC1
CMAKE_C_FLAGS_MINSIZEREL:STRING=/MD /O1 /Ob1 /D NDEBUG
// files).
CMAKE_C_FLAGS_RELEASE:STRING=/MD /O2 /Ob2 /D NDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=/MD /Zi /O2 /Ob1 /D NDEBUG
//Libraries linked by defalut with all C applications.
CMAKE_C_STANDARD_LIBRARIES:STRING='kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib '
//Flags used by the linker.
CMAKE_EXE_LINKER_FLAGS:STRING= /STACK:10000000 /machine:X86
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL:YES
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
//Flags used by the linker during release builds.
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL:YES
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=C:/Program Files/qgis1.7.0
CMAKE_LINKER:FILEPATH=CMAKE_LINKER-NOTFOUND
//make program
CMAKE_MAKE_PROGRAM:FILEPATH=C:/PROGRA~1/MICROS~1.0/Common7/IDE/VCExpress.exe
//Flags used by the linker during the creation of modules.
CMAKE_MODULE_LINKER_FLAGS:STRING= /STACK:10000000 /machine:X86
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL:YES
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL:YES
//Value Computed by CMake
CMAKE_PROJECT_NAME:STATIC=qgis1.7.0
//RC compiler
CMAKE_RC_COMPILER:FILEPATH=rc
//Flags for Fortran compiler.
CMAKE_RC_FLAGS:STRING=' '
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING= /STACK:10000000 /machine:X86
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=/debug /INCREMENTAL:YES
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=/INCREMENTAL:NO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=/debug /INCREMENTAL:YES
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=OFF
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make.  This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=OFF
//Enable to build NSIS packages
CPACK_BINARY_NSIS:BOOL=ON
//Enable to build ZIP packages
CPACK_BINARY_ZIP:BOOL=OFF
//Enable to build ZIP source packages
CPACK_SOURCE_ZIP:BOOL=ON
//Build unit tests?
ENABLE_TESTS:BOOL=OFF
//Path to a file.
EXPAT_INCLUDE_DIR:PATH=EXPAT_INCLUDE_DIR-NOTFOUND
//Path to a library.
EXPAT_LIBRARY:FILEPATH=EXPAT_LIBRARY-NOTFOUND
//Path to a file.
FCGI_INCLUDE_DIR:PATH=C:/OSGeo4W/include
FCGI_LIBRARY:FILEPATH=C:/OSGeo4W/lib/libfcgi.lib
FLEX_EXECUTABLE:FILEPATH=C:/Program Files/GnuWin32/bin/flex.exe
//Path to a file.
GDAL_INCLUDE_DIR:PATH=C:/OSGeo4W/apps/gdal-17/include
GDAL_LIBRARY:FILEPATH=C:/OSGeo4W/apps/gdal-17/lib/gdal_i.lib
//Path to a file.
GEOS_INCLUDE_DIR:PATH=C:/OSGeo4W/include/geos
GEOS_LIBRARY:FILEPATH=C:/OSGeo4W/lib/geos_c_i.lib
//Path to a file.
GIT_MARKER:FILEPATH=GIT_MARKER-NOTFOUND
//Path to a file.
GRASS_INCLUDE_DIR:PATH=C:/OSGeo4W/apps/grass/grass-6.4.1/include
//Path to GRASS base directory
GRASS_PREFIX:PATH=C:/OSGeo4W/apps/grass/grass-6.4.1
GSLCBLAS_LIB:FILEPATH=GSLCBLAS_LIB-NOTFOUND
//Path to a file.
GSL_INCLUDE_DIR:PATH=C:/OSGeo4W/include/gsl
GSL_LIB:FILEPATH=C:/OSGeo4W/lib/gsl.lib
//Path to a file.
ICONV_INCLUDE_DIR:PATH=C:/OSGeo4W/include
ICONV_LIBRARY:FILEPATH=C:/OSGeo4W/lib/iconv.lib
LIB_PATH:FILEPATH=C:/OSGeo4W/apps/grass/grass-6.4.1/lib/grass_gproj.lib
//Path to a file.
MSVC90_REDIST_DIR:PATH=C:/Program Files/Microsoft Visual Studio 9.0/VC/redist
//Determines if we should compile in pedantic mode.
PEDANTIC:BOOL=OFF
//Path to POSTGRESQL base directory
POSTGRESQL_PREFIX:PATH=
//Path to a file.
POSTGRES_INCLUDE_DIR:PATH=C:/OSGeo4W/include
POSTGRES_LIBRARY:FILEPATH=C:/OSGeo4W/lib/libpq.lib
//Path to a file.
PROJ_INCLUDE_DIR:PATH=C:/OSGeo4W/share/proj
PROJ_LIBRARY:FILEPATH=C:/OSGeo4W/lib/libproj.a
PYTHON_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/python.exe
//Subdirectory where executables will be installed
QGIS_BIN_SUBDIR:STRING=bin
//Subdirectory where CGI executables will be installed
QGIS_CGIBIN_SUBDIR:STRING=bin
//Subdirectory where QGIS data will be installed
QGIS_DATA_SUBDIR:STRING=.
//Subdirectory where header files will be installed
QGIS_INCLUDE_SUBDIR:STRING=include
//Subdirectory where private executables will be installed
QGIS_LIBEXEC_SUBDIR:STRING=.
//Subdirectory where libraries will be installed
QGIS_LIB_SUBDIR:STRING=lib
//Subdirectory where plugins will be installed
QGIS_PLUGIN_SUBDIR:STRING=plugins
QT_ARTHURPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_ARTHURPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_RELEASE-NOTFOUND
QT_CONTAINEREXTENSION_PLUGIN_DEBUG:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_DEBUG-NOTFOUND
QT_CONTAINEREXTENSION_PLUGIN_RELEASE:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_RELEASE-NOTFOUND
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-NOTFOUND
QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=QT_DBUSCPP2XML_EXECUTABLE-NOTFOUND
QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=QT_DBUSXML2CPP_EXECUTABLE-NOTFOUND
QT_DESIGNER_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/designer.exe
//The location of the Qt docs
QT_DOC_DIR:PATH=C:/OSGeo4W/apps/qt4/doc
//The location of the Qt imports
QT_IMPORTS_DIR:PATH=C:/OSGeo4W/apps/qt4/imports
QT_LINGUIST_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/linguist.exe
QT_LRELEASE_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/lrelease.exe
QT_LUPDATE_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/lupdate.exe
//The location of the Qt mkspecs containing qconfig.pri
QT_MKSPECS_DIR:PATH=C:/OSGeo4W/apps/qt4/mkspecs
QT_MOC_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/moc.exe
QT_PHONONWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_PHONONWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_PHONONWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/designer/phononwidgets.dll
//Path to a file.
QT_PHONON_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/phonon
//The Qt PHONON library
QT_PHONON_LIBRARY:STRING=C:/OSGeo4W/lib/phonon4.lib
QT_PHONON_LIBRARY_DEBUG:FILEPATH=QT_PHONON_LIBRARY_DEBUG-NOTFOUND
QT_PHONON_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/phonon4.lib
QT_PHONON_QT7_PLUGIN_DEBUG:FILEPATH=QT_PHONON_QT7_PLUGIN_DEBUG-NOTFOUND
QT_PHONON_QT7_PLUGIN_RELEASE:FILEPATH=QT_PHONON_QT7_PLUGIN_RELEASE-NOTFOUND
//The location of the Qt plugins
QT_PLUGINS_DIR:PATH=C:/OSGeo4W/apps/qt4/plugins
//Path to a file.
QT_QAXCONTAINER_INCLUDE_DIR:PATH=QT_QAXCONTAINER_INCLUDE_DIR-NOTFOUND
//The Qt QAXCONTAINER library
QT_QAXCONTAINER_LIBRARY:STRING=optimized;C:/OSGeo4W/lib/qaxcontainer.lib;debug;C:/OSGeo4W/lib/qaxcontainer.lib
QT_QAXCONTAINER_LIBRARY_DEBUG:FILEPATH=QT_QAXCONTAINER_LIBRARY_DEBUG-NOTFOUND
QT_QAXCONTAINER_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/qaxcontainer.lib
//Path to a file.
QT_QAXSERVER_INCLUDE_DIR:PATH=QT_QAXSERVER_INCLUDE_DIR-NOTFOUND
//The Qt QAXSERVER library
QT_QAXSERVER_LIBRARY:STRING=optimized;C:/OSGeo4W/lib/qaxserver.lib;debug;C:/OSGeo4W/lib/qaxserver.lib
QT_QAXSERVER_LIBRARY_DEBUG:FILEPATH=QT_QAXSERVER_LIBRARY_DEBUG-NOTFOUND
QT_QAXSERVER_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/qaxserver.lib
QT_QCNCODECS_PLUGIN_DEBUG:FILEPATH=QT_QCNCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QCNCODECS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/codecs/qcncodecs4.dll
QT_QCOLLECTIONGENERATOR_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/qcollectiongenerator.exe
QT_QCOREWLANBEARER_PLUGIN_DEBUG:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_DEBUG-NOTFOUND
QT_QCOREWLANBEARER_PLUGIN_RELEASE:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_RELEASE-NOTFOUND
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG:FILEPATH=QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/designer/qdeclarativeview.dll
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-NOTFOUND
QT_QGENERICBEARER_PLUGIN_DEBUG:FILEPATH=QT_QGENERICBEARER_PLUGIN_DEBUG-NOTFOUND
QT_QGENERICBEARER_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/bearer/qgenericbearer4.dll
QT_QGIF_PLUGIN_DEBUG:FILEPATH=QT_QGIF_PLUGIN_DEBUG-NOTFOUND
QT_QGIF_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/imageformats/qgif4.dll
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/graphicssystems/qglgraphicssystem4.dll
QT_QICO_PLUGIN_DEBUG:FILEPATH=QT_QICO_PLUGIN_DEBUG-NOTFOUND
QT_QICO_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/imageformats/qico4.dll
QT_QIMSW_MULTI_PLUGIN_DEBUG:FILEPATH=QT_QIMSW_MULTI_PLUGIN_DEBUG-NOTFOUND
QT_QIMSW_MULTI_PLUGIN_RELEASE:FILEPATH=QT_QIMSW_MULTI_PLUGIN_RELEASE-NOTFOUND
QT_QJPCODECS_PLUGIN_DEBUG:FILEPATH=QT_QJPCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QJPCODECS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/codecs/qjpcodecs4.dll
QT_QJPEG_PLUGIN_DEBUG:FILEPATH=QT_QJPEG_PLUGIN_DEBUG-NOTFOUND
QT_QJPEG_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/imageformats/qjpeg4.dll
QT_QKRCODECS_PLUGIN_DEBUG:FILEPATH=QT_QKRCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QKRCODECS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/codecs/qkrcodecs4.dll
//Invalid qmake found
QT_QMAKE_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/qmake.exe
QT_QMNG_PLUGIN_DEBUG:FILEPATH=QT_QMNG_PLUGIN_DEBUG-NOTFOUND
QT_QMNG_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/imageformats/qmng4.dll
QT_QSQLDB2_PLUGIN_DEBUG:FILEPATH=QT_QSQLDB2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLDB2_PLUGIN_RELEASE:FILEPATH=QT_QSQLDB2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLIBASE_PLUGIN_DEBUG:FILEPATH=QT_QSQLIBASE_PLUGIN_DEBUG-NOTFOUND
QT_QSQLIBASE_PLUGIN_RELEASE:FILEPATH=QT_QSQLIBASE_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE2_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLITE2_PLUGIN_RELEASE:FILEPATH=QT_QSQLITE2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE_PLUGIN_DEBUG-NOTFOUND
QT_QSQLITE_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/sqldrivers/qsqlite4.dll
QT_QSQLMYSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLMYSQL_PLUGIN_DEBUG-NOTFOUND
QT_QSQLMYSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLMYSQL_PLUGIN_RELEASE-NOTFOUND
QT_QSQLOCI_PLUGIN_DEBUG:FILEPATH=QT_QSQLOCI_PLUGIN_DEBUG-NOTFOUND
QT_QSQLOCI_PLUGIN_RELEASE:FILEPATH=QT_QSQLOCI_PLUGIN_RELEASE-NOTFOUND
QT_QSQLODBC_PLUGIN_DEBUG:FILEPATH=QT_QSQLODBC_PLUGIN_DEBUG-NOTFOUND
QT_QSQLODBC_PLUGIN_RELEASE:FILEPATH=QT_QSQLODBC_PLUGIN_RELEASE-NOTFOUND
QT_QSQLPSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLPSQL_PLUGIN_DEBUG-NOTFOUND
QT_QSQLPSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLPSQL_PLUGIN_RELEASE-NOTFOUND
QT_QSQLTDS_PLUGIN_DEBUG:FILEPATH=QT_QSQLTDS_PLUGIN_DEBUG-NOTFOUND
QT_QSQLTDS_PLUGIN_RELEASE:FILEPATH=QT_QSQLTDS_PLUGIN_RELEASE-NOTFOUND
QT_QSVGICON_PLUGIN_DEBUG:FILEPATH=QT_QSVGICON_PLUGIN_DEBUG-NOTFOUND
QT_QSVGICON_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/iconengines/qsvgicon4.dll
QT_QSVG_PLUGIN_DEBUG:FILEPATH=QT_QSVG_PLUGIN_DEBUG-NOTFOUND
QT_QSVG_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/imageformats/qsvg4.dll
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/designer/qt3supportwidgets.dll
//Path to a file.
QT_QT3SUPPORT_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/Qt3Support
//The Qt QT3SUPPORT library
QT_QT3SUPPORT_LIBRARY:STRING=C:/OSGeo4W/lib/Qt3Support4.lib
QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND
QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/Qt3Support4.lib
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/accessible/qtaccessiblecompatwidgets4.dll
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/accessible/qtaccessiblewidgets4.dll
//Path to a file.
QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=QT_QTASSISTANTCLIENT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANTCLIENT library
QT_QTASSISTANTCLIENT_LIBRARY:STRING=
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTASSISTANT_INCLUDE_DIR:PATH=QT_QTASSISTANT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANT library
QT_QTASSISTANT_LIBRARY:STRING=
QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANT_LIBRARY_RELEASE-NOTFOUND
//The Qt QTCLUCENE library
QT_QTCLUCENE_LIBRARY:STRING=C:/OSGeo4W/lib/QtCLucene4.lib
QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=QT_QTCLUCENE_LIBRARY_DEBUG-NOTFOUND
QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtCLucene4.lib
//(This variable does not exist and should not be used)
QT_QTCORE_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtCore
//The Qt QTCORE library
QT_QTCORE_LIBRARY:STRING=C:/OSGeo4W/lib/QtCore4.lib
QT_QTCORE_LIBRARY_DEBUG:FILEPATH=QT_QTCORE_LIBRARY_DEBUG-NOTFOUND
QT_QTCORE_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtCore4.lib
//Path to a file.
QT_QTDBUS_INCLUDE_DIR:PATH=QT_QTDBUS_INCLUDE_DIR-NOTFOUND
//The Qt QTDBUS library
QT_QTDBUS_LIBRARY:STRING=
QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND
QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=QT_QTDBUS_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTDECLARATIVE_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtDeclarative
//The Qt QTDECLARATIVE library
QT_QTDECLARATIVE_LIBRARY:STRING=C:/OSGeo4W/lib/QtDeclarative4.lib
QT_QTDECLARATIVE_LIBRARY_DEBUG:FILEPATH=QT_QTDECLARATIVE_LIBRARY_DEBUG-NOTFOUND
QT_QTDECLARATIVE_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtDeclarative4.lib
//Path to a file.
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtDesigner
//The Qt QTDESIGNERCOMPONENTS library
QT_QTDESIGNERCOMPONENTS_LIBRARY:STRING=C:/OSGeo4W/lib/QtDesignerComponents4.lib
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-NOTFOUND
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtDesignerComponents4.lib
//Path to a file.
QT_QTDESIGNER_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtDesigner
//The Qt QTDESIGNER library
QT_QTDESIGNER_LIBRARY:STRING=C:/OSGeo4W/lib/QtDesigner4.lib
QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND
QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtDesigner4.lib
//Path to a file.
QT_QTGUI_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtGui
//The Qt QTGUI library
QT_QTGUI_LIBRARY:STRING=C:/OSGeo4W/lib/QtGui4.lib
QT_QTGUI_LIBRARY_DEBUG:FILEPATH=QT_QTGUI_LIBRARY_DEBUG-NOTFOUND
QT_QTGUI_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtGui4.lib
//Path to a file.
QT_QTHELP_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtHelp
//The Qt QTHELP library
QT_QTHELP_LIBRARY:STRING=C:/OSGeo4W/lib/QtHelp4.lib
QT_QTHELP_LIBRARY_DEBUG:FILEPATH=QT_QTHELP_LIBRARY_DEBUG-NOTFOUND
QT_QTHELP_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtHelp4.lib
QT_QTIFF_PLUGIN_DEBUG:FILEPATH=QT_QTIFF_PLUGIN_DEBUG-NOTFOUND
QT_QTIFF_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/imageformats/qtiff4.dll
//The Qt QTMAIN library
QT_QTMAIN_LIBRARY:STRING=C:/OSGeo4W/lib/qtmain.lib
QT_QTMAIN_LIBRARY_DEBUG:FILEPATH=QT_QTMAIN_LIBRARY_DEBUG-NOTFOUND
QT_QTMAIN_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/qtmain.lib
//Path to a file.
QT_QTMULTIMEDIA_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtMultimedia
//The Qt QTMULTIMEDIA library
QT_QTMULTIMEDIA_LIBRARY:STRING=C:/OSGeo4W/lib/qtmultimedia4.lib
QT_QTMULTIMEDIA_LIBRARY_DEBUG:FILEPATH=QT_QTMULTIMEDIA_LIBRARY_DEBUG-NOTFOUND
QT_QTMULTIMEDIA_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/qtmultimedia4.lib
//Path to a file.
QT_QTNETWORK_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtNetwork
//The Qt QTNETWORK library
QT_QTNETWORK_LIBRARY:STRING=C:/OSGeo4W/lib/QtNetwork4.lib
QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND
QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtNetwork4.lib
//Path to a file.
QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
//The Qt QTNSPLUGIN library
QT_QTNSPLUGIN_LIBRARY:STRING=
QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTOPENGL_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtOpenGL
//The Qt QTOPENGL library
QT_QTOPENGL_LIBRARY:STRING=C:/OSGeo4W/lib/QtOpenGL4.lib
QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND
QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtOpenGL4.lib
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/graphicssystems/qtracegraphicssystem4.dll
QT_QTSCRIPTDBUS_PLUGIN_DEBUG:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_DEBUG-NOTFOUND
QT_QTSCRIPTDBUS_PLUGIN_RELEASE:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_RELEASE-NOTFOUND
//Path to a file.
QT_QTSCRIPTTOOLS_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtScriptTools
//The Qt QTSCRIPTTOOLS library
QT_QTSCRIPTTOOLS_LIBRARY:STRING=C:/OSGeo4W/lib/QtScriptTools4.lib
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-NOTFOUND
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtScriptTools4.lib
//Path to a file.
QT_QTSCRIPT_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtScript
//The Qt QTSCRIPT library
QT_QTSCRIPT_LIBRARY:STRING=C:/OSGeo4W/lib/QtScript4.lib
QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPT_LIBRARY_DEBUG-NOTFOUND
QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtScript4.lib
//Path to a file.
QT_QTSQL_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtSql
//The Qt QTSQL library
QT_QTSQL_LIBRARY:STRING=C:/OSGeo4W/lib/QtSql4.lib
QT_QTSQL_LIBRARY_DEBUG:FILEPATH=QT_QTSQL_LIBRARY_DEBUG-NOTFOUND
QT_QTSQL_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtSql4.lib
//Path to a file.
QT_QTSVG_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtSvg
//The Qt QTSVG library
QT_QTSVG_LIBRARY:STRING=C:/OSGeo4W/lib/QtSvg4.lib
QT_QTSVG_LIBRARY_DEBUG:FILEPATH=QT_QTSVG_LIBRARY_DEBUG-NOTFOUND
QT_QTSVG_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtSvg4.lib
//Path to a file.
QT_QTTEST_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtTest
//The Qt QTTEST library
QT_QTTEST_LIBRARY:STRING=C:/OSGeo4W/lib/QtTest4.lib
QT_QTTEST_LIBRARY_DEBUG:FILEPATH=QT_QTTEST_LIBRARY_DEBUG-NOTFOUND
QT_QTTEST_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtTest4.lib
//Path to a file.
QT_QTUITOOLS_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtUiTools
//The Qt QTUITOOLS library
QT_QTUITOOLS_LIBRARY:STRING=C:/OSGeo4W/lib/QtUiTools.lib
QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTUITOOLS_LIBRARY_DEBUG-NOTFOUND
QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtUiTools.lib
QT_QTWCODECS_PLUGIN_DEBUG:FILEPATH=QT_QTWCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QTWCODECS_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/codecs/qtwcodecs4.dll
//Path to a file.
QT_QTWEBKIT_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtWebKit
//The Qt QTWEBKIT library
QT_QTWEBKIT_LIBRARY:STRING=C:/OSGeo4W/lib/QtWebKit4.lib
QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=QT_QTWEBKIT_LIBRARY_DEBUG-NOTFOUND
QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtWebKit4.lib
//Path to a file.
QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtXmlPatterns
//The Qt QTXMLPATTERNS library
QT_QTXMLPATTERNS_LIBRARY:STRING=C:/OSGeo4W/lib/QtXmlPatterns4.lib
QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=QT_QTXMLPATTERNS_LIBRARY_DEBUG-NOTFOUND
QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtXmlPatterns4.lib
//Path to a file.
QT_QTXML_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qt4/QtXml
//The Qt QTXML library
QT_QTXML_LIBRARY:STRING=C:/OSGeo4W/lib/QtXml4.lib
QT_QTXML_LIBRARY_DEBUG:FILEPATH=QT_QTXML_LIBRARY_DEBUG-NOTFOUND
QT_QTXML_LIBRARY_RELEASE:FILEPATH=C:/OSGeo4W/lib/QtXml4.lib
QT_QWEBVIEW_PLUGIN_DEBUG:FILEPATH=QT_QWEBVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QWEBVIEW_PLUGIN_RELEASE:FILEPATH=C:/OSGeo4W/apps/qt4/plugins/designer/qwebview.dll
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-NOTFOUND
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-NOTFOUND
QT_RCC_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/rcc.exe
QT_TASKMENUEXTENSION_PLUGIN_DEBUG:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_DEBUG-NOTFOUND
QT_TASKMENUEXTENSION_PLUGIN_RELEASE:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_RELEASE-NOTFOUND
//The location of the Qt translations
QT_TRANSLATIONS_DIR:PATH=C:/OSGeo4W/apps/qt4/translations
QT_UIC3_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/uic3.exe
QT_UIC_EXECUTABLE:FILEPATH=C:/OSGeo4W/bin/uic.exe
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-NOTFOUND
//Path to a file.
QWT_INCLUDE_DIR:PATH=C:/OSGeo4W/include/qwt
QWT_LIBRARY:FILEPATH=C:/OSGeo4W/lib/qwt5.lib
SETUPAPI_LIBRARY:FILEPATH=C:/Program Files/Microsoft Platform SDK for Windows Server 2003 R2/Lib/SetupAPI.Lib
SVNVERSION:FILEPATH=C:/Program Files/TortoiseSVN/bin/TortoiseProc.exe
//Path to a file.
SVN_MARKER:FILEPATH=C:/qgis_source/.svn/entries
TXT2TAGS_EXECUTABLE:FILEPATH=TXT2TAGS_EXECUTABLE-NOTFOUND
//Determines whether the QGIS API doxygen documentation should
// be built
WITH_APIDOC:BOOL=OFF
//Determines whether python bindings should be built
WITH_BINDINGS:BOOL=ON
//Determines whether GRASS plugin should be built
WITH_GRASS:BOOL=ON
//Use internal built of QwtPolar
WITH_INTERNAL_QWTPOLAR:BOOL=ON
//Determines whether SPATIALITE support should be built internally
WITH_INTERNAL_SPATIALITE:BOOL=ON
//Determines whether QGIS mapserver should be built
WITH_MAPSERVER:BOOL=ON
//Determines whether POSTGRESQL support should be built
WITH_POSTGRESQL:BOOL=ON
WITH_SPATIALITE:BOOL=ON
//Path to a file.
_find_lib_python_py:FILEPATH=C:/qgis_source/cmake/FindLibPython.py
//Path to a file.
_find_sip_py:FILEPATH=C:/qgis_source/cmake/FindSIP.py
//Dependencies for the target
coordinatecaptureplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
copyrightlabelplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
delimitedtextplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
delimitedtextprovider_LIB_DEPENDS:STATIC=general;qgis_core;
diagramoverlay_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
displacementplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
dxf2shpconverterplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
evis_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;general;C:/OSGeo4W/lib/QtSql4.lib;
gdalprovider_LIB_DEPENDS:STATIC=general;qgis_core;
grassplugin_LIB_DEPENDS:STATIC=general;qgisgrass;general;qgis_gui;
grassprovider_LIB_DEPENDS:STATIC=general;qgisgrass;
grassrasterprovider_LIB_DEPENDS:STATIC=general;qgisgrass;general;qgis_core;
interpolationplugin_LIB_DEPENDS:STATIC=general;qgis_analysis;general;qgis_core;general;qgis_gui;
memoryprovider_LIB_DEPENDS:STATIC=general;qgis_core;
northarrowplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
offlineeditingplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
ogrprovider_LIB_DEPENDS:STATIC=general;qgis_core;
oracleplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
osmprovider_LIB_DEPENDS:STATIC=general;qgis_core;
postgresprovider_LIB_DEPENDS:STATIC=general;C:/OSGeo4W/lib/libpq.lib;general;qgis_core;
qgis1.7.0_BINARY_DIR:STATIC=C:/qgis_source/build
qgis1.7.0_SOURCE_DIR:STATIC=C:/qgis_source
qgis_analysis_LIB_DEPENDS:STATIC=general;qgis_core;
qgis_core_LIB_DEPENDS:STATIC=general;wsock32;general;C:/Program Files/Microsoft Platform SDK for Windows Server 2003 R2/Lib/SetupAPI.Lib;general;C:/OSGeo4W/lib/qtmain.lib;general;C:/OSGeo4W/lib/QtXml4.lib;general;C:/OSGeo4W/lib/QtCore4.lib;general;C:/OSGeo4W/lib/QtGui4.lib;general;C:/OSGeo4W/lib/QtNetwork4.lib;general;C:/OSGeo4W/lib/QtSvg4.lib;general;C:/OSGeo4W/lib/libproj.a;general;C:/OSGeo4W/lib/geos_c_i.lib;general;C:/OSGeo4W/apps/gdal-17/lib/gdal_i.lib;general;C:/OSGeo4W/lib/iconv.lib;
qgis_gui_LIB_DEPENDS:STATIC=general;qgis_core;general;C:/OSGeo4W/lib/QtUiTools.lib;
qgisgrass_LIB_DEPENDS:STATIC=general;qgis_core;general;C:/OSGeo4W/apps/grass/grass-6.4.1/lib/grass_gis.lib;general;C:/OSGeo4W/apps/grass/grass-6.4.1/lib/grass_vect.lib;general;C:/OSGeo4W/apps/grass/grass-6.4.1/lib/grass_dbmibase.lib;general;C:/OSGeo4W/apps/grass/grass-6.4.1/lib/grass_dbmiclient.lib;general;C:/OSGeo4W/apps/grass/grass-6.4.1/lib/grass_gproj.lib;
qgissqlanyconnection_LIB_DEPENDS:STATIC=general;qgis_core;
rasterterrainplugin_LIB_DEPENDS:STATIC=general;qgis_analysis;general;qgis_core;general;qgis_gui;
roadgraphplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
scalebarplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
spatialiteprovider_LIB_DEPENDS:STATIC=general;qgis_core;
spatialqueryplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;
spitplugin_LIB_DEPENDS:STATIC=general;C:/OSGeo4W/lib/libpq.lib;general;qgis_core;general;qgis_gui;
sqlanywhereplugin_LIB_DEPENDS:STATIC=general;qgis_core;general;qgis_gui;general;qgissqlanyconnection;
sqlanywhereprovider_LIB_DEPENDS:STATIC=general;qgis_core;general;qgissqlanyconnection;
wmsprovider_LIB_DEPENDS:STATIC=general;qgis_core;
# INTERNAL cache entries
//Stored GUID
ALL_BUILD_GUID_CMAKE:INTERNAL=10438B85-E32E-4AC5-95A7-CC5F1FC4C735
//ADVANCED property for variable: CMAKE_BUILD_TOOL
CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1
//What is the target build tool cmake is generating for.
CMAKE_BUILD_TOOL:INTERNAL=C:/PROGRA~1/MICROS~1.0/Common7/IDE/VCExpress.exe
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=c:/qgis_source/build
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=8
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=4
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=C:/Program Files/CMake 2.8/bin/cmake.exe
//ADVANCED property for variable: CMAKE_CONFIGURATION_TYPES
CMAKE_CONFIGURATION_TYPES-ADVANCED:INTERNAL=1
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=C:/Program Files/CMake 2.8/bin/cpack.exe
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=C:/Program Files/CMake 2.8/bin/ctest.exe
//ADVANCED property for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
CMAKE_CXX_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_STANDARD_LIBRARIES
CMAKE_CXX_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
CMAKE_C_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_STANDARD_LIBRARIES
CMAKE_C_STANDARD_LIBRARIES-ADVANCED:INTERNAL=1
//Result of TRY_COMPILE
CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE
CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=C:/Program Files/CMake 2.8/bin/cmake-gui.exe
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Visual Studio 9 2008
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=C:/qgis_source
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=1
//ADVANCED property for variable: CMAKE_RC_COMPILER
CMAKE_RC_COMPILER-ADVANCED:INTERNAL=1
CMAKE_RC_COMPILER_WORKS:INTERNAL=1
//ADVANCED property for variable: CMAKE_RC_FLAGS
CMAKE_RC_FLAGS-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=C:/Program Files/CMake 2.8/share/cmake-2.8
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//Suppress Warnings that are meant for the author of the CMakeLists.txt
// files.
CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CPACK_BINARY_NSIS
CPACK_BINARY_NSIS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CPACK_BINARY_ZIP
CPACK_BINARY_ZIP-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CPACK_SOURCE_ZIP
CPACK_SOURCE_ZIP-ADVANCED:INTERNAL=1
//Stored GUID
EDIT_CACHE_GUID_CMAKE:INTERNAL=D3A538B8-C089-4060-B929-018B599A8AA7
//Details about finding PythonInterp
FIND_PACKAGE_MESSAGE_DETAILS_PythonInterp:INTERNAL=[C:/OSGeo4W/bin/python.exe][v()]
//Details about finding Qt4
FIND_PACKAGE_MESSAGE_DETAILS_Qt4:INTERNAL=[C:/OSGeo4W/lib][C:/OSGeo4W/include/qt4][C:/OSGeo4W/bin/moc.exe][C:/OSGeo4W/bin/uic.exe][C:/OSGeo4W/bin/rcc.exe]
//ADVANCED property for variable: GRASS_INCLUDE_DIR
GRASS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//Stored GUID
INSTALL_GUID_CMAKE:INTERNAL=4781C34D-1AAE-4AEF-8352-DEF6142EDA7F
//ADVANCED property for variable: LIB_PATH
LIB_PATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: MSVC90_REDIST_DIR
MSVC90_REDIST_DIR-ADVANCED:INTERNAL=1
//Stored GUID
PACKAGE_GUID_CMAKE:INTERNAL=21C83181-9116-4347-9C20-7475FF017FD4
//ADVANCED property for variable: PYTHON_EXECUTABLE
PYTHON_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QGIS_BIN_SUBDIR
QGIS_BIN_SUBDIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QGIS_CGIBIN_SUBDIR
QGIS_CGIBIN_SUBDIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QGIS_DATA_SUBDIR
QGIS_DATA_SUBDIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QGIS_INCLUDE_SUBDIR
QGIS_INCLUDE_SUBDIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QGIS_LIBEXEC_SUBDIR
QGIS_LIBEXEC_SUBDIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QGIS_LIB_SUBDIR
QGIS_LIB_SUBDIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QGIS_PLUGIN_SUBDIR
QGIS_PLUGIN_SUBDIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_DEBUG
QT_ARTHURPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_RELEASE
QT_ARTHURPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_BINARY_DIR:INTERNAL=C:/OSGeo4W/bin
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_DEBUG
QT_CONTAINEREXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_RELEASE
QT_CONTAINEREXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSCPP2XML_EXECUTABLE
QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSXML2CPP_EXECUTABLE
QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DESIGNER_EXECUTABLE
QT_DESIGNER_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DOC_DIR
QT_DOC_DIR-ADVANCED:INTERNAL=1
QT_HEADERS_DIR:INTERNAL=C:/OSGeo4W/include/qt4
//ADVANCED property for variable: QT_IMPORTS_DIR
QT_IMPORTS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LIBRARY_DIR
QT_LIBRARY_DIR-ADVANCED:INTERNAL=1
//Qt library dir
QT_LIBRARY_DIR:INTERNAL=C:/OSGeo4W/lib
//ADVANCED property for variable: QT_LINGUIST_EXECUTABLE
QT_LINGUIST_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LRELEASE_EXECUTABLE
QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LUPDATE_EXECUTABLE
QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_MKSPECS_DIR
QT_MKSPECS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_MOC_EXECUTABLE
QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_DEBUG
QT_PHONONWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_RELEASE
QT_PHONONWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_INCLUDE_DIR
QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY
QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_DEBUG
QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_RELEASE
QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_QT7_PLUGIN_DEBUG
QT_PHONON_QT7_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_QT7_PLUGIN_RELEASE
QT_PHONON_QT7_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PLUGINS_DIR
QT_PLUGINS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_INCLUDE_DIR
QT_QAXCONTAINER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY
QT_QAXCONTAINER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY_DEBUG
QT_QAXCONTAINER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXCONTAINER_LIBRARY_RELEASE
QT_QAXCONTAINER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_INCLUDE_DIR
QT_QAXSERVER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY
QT_QAXSERVER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY_DEBUG
QT_QAXSERVER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QAXSERVER_LIBRARY_RELEASE
QT_QAXSERVER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_DEBUG
QT_QCNCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_RELEASE
QT_QCNCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOLLECTIONGENERATOR_EXECUTABLE
QT_QCOLLECTIONGENERATOR_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_DEBUG
QT_QCOREWLANBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_RELEASE
QT_QCOREWLANBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_DEBUG
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_RELEASE
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_DEBUG
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_RELEASE
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_DEBUG
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_RELEASE
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_DEBUG
QT_QGENERICBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_RELEASE
QT_QGENERICBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_DEBUG
QT_QGIF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_RELEASE
QT_QGIF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_DEBUG
QT_QICO_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_RELEASE
QT_QICO_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_DEBUG
QT_QIMSW_MULTI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_RELEASE
QT_QIMSW_MULTI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_DEBUG
QT_QJPCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_RELEASE
QT_QJPCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_DEBUG
QT_QJPEG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_RELEASE
QT_QJPEG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_DEBUG
QT_QKRCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_RELEASE
QT_QKRCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_QMAKE_EXECUTABLE_LAST:INTERNAL=C:/OSGeo4W/bin/qmake.exe
//ADVANCED property for variable: QT_QMNG_PLUGIN_DEBUG
QT_QMNG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QMNG_PLUGIN_RELEASE
QT_QMNG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_DEBUG
QT_QSQLDB2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_RELEASE
QT_QSQLDB2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_DEBUG
QT_QSQLIBASE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_RELEASE
QT_QSQLIBASE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_DEBUG
QT_QSQLITE2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_RELEASE
QT_QSQLITE2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_DEBUG
QT_QSQLITE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_RELEASE
QT_QSQLITE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_DEBUG
QT_QSQLMYSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_RELEASE
QT_QSQLMYSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_DEBUG
QT_QSQLOCI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_RELEASE
QT_QSQLOCI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_DEBUG
QT_QSQLODBC_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_RELEASE
QT_QSQLODBC_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_DEBUG
QT_QSQLPSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_RELEASE
QT_QSQLPSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_DEBUG
QT_QSQLTDS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_RELEASE
QT_QSQLTDS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_DEBUG
QT_QSVGICON_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_RELEASE
QT_QSVGICON_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_DEBUG
QT_QSVG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_RELEASE
QT_QSVG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_INCLUDE_DIR
QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY
QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_DEBUG
QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_RELEASE
QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR
QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY
QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_INCLUDE_DIR
QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY
QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_DEBUG
QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_RELEASE
QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY
QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_DEBUG
QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_RELEASE
QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_INCLUDE_DIR
QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY
QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_DEBUG
QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_RELEASE
QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_INCLUDE_DIR
QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY
QT_QTDBUS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_DEBUG
QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_RELEASE
QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_INCLUDE_DIR
QT_QTDECLARATIVE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY
QT_QTDECLARATIVE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_DEBUG
QT_QTDECLARATIVE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_RELEASE
QT_QTDECLARATIVE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY
QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR
QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY
QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_DEBUG
QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_RELEASE
QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_INCLUDE_DIR
QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY
QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_DEBUG
QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_RELEASE
QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_INCLUDE_DIR
QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY
QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_DEBUG
QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_RELEASE
QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_DEBUG
QT_QTIFF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_RELEASE
QT_QTIFF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY
QT_QTMAIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY_DEBUG
QT_QTMAIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMAIN_LIBRARY_RELEASE
QT_QTMAIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_INCLUDE_DIR
QT_QTMULTIMEDIA_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY
QT_QTMULTIMEDIA_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_DEBUG
QT_QTMULTIMEDIA_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_RELEASE
QT_QTMULTIMEDIA_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_INCLUDE_DIR
QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY
QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_DEBUG
QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_RELEASE
QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_INCLUDE_DIR
QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY
QT_QTNSPLUGIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG
QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE
QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_INCLUDE_DIR
QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY
QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_DEBUG
QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_RELEASE
QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_DEBUG
QT_QTSCRIPTDBUS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_RELEASE
QT_QTSCRIPTDBUS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_INCLUDE_DIR
QT_QTSCRIPTTOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY
QT_QTSCRIPTTOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_DEBUG
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_RELEASE
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_INCLUDE_DIR
QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY
QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_DEBUG
QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_RELEASE
QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_INCLUDE_DIR
QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY
QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_DEBUG
QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_RELEASE
QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_INCLUDE_DIR
QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY
QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_DEBUG
QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_RELEASE
QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_INCLUDE_DIR
QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY
QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_DEBUG
QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_RELEASE
QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_INCLUDE_DIR
QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY
QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_DEBUG
QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_RELEASE
QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_DEBUG
QT_QTWCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_RELEASE
QT_QTWCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_INCLUDE_DIR
QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY
QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_DEBUG
QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_RELEASE
QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_INCLUDE_DIR
QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY
QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG
QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE
QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_INCLUDE_DIR
QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY
QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_DEBUG
QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_RELEASE
QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_DEBUG
QT_QWEBVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_RELEASE
QT_QWEBVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_RCC_EXECUTABLE
QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_DEBUG
QT_TASKMENUEXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_RELEASE
QT_TASKMENUEXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TRANSLATIONS_DIR
QT_TRANSLATIONS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC3_EXECUTABLE
QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC_EXECUTABLE
QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//Have symbol Q_WS_MAC
Q_WS_MAC:INTERNAL=
//Have symbol Q_WS_QWS
Q_WS_QWS:INTERNAL=
//Have symbol Q_WS_WIN
Q_WS_WIN:INTERNAL=1
//Have symbol Q_WS_X11
Q_WS_X11:INTERNAL=
//Stored GUID
REBUILD_CACHE_GUID_CMAKE:INTERNAL=C49DB5B3-1B45-40DC-870A-6F4BD2568CE3
//Stored GUID
RUN_TESTS_GUID_CMAKE:INTERNAL=07C9EC70-B0CE-4B0B-84A5-B2ACE3E69C04
//Stored GUID
SG_Filter_CMake Rules_GUID_CMAKE:INTERNAL=225E3B49-3B91-43CD-BF4F-1C67E35B6608
//Stored GUID
SG_Filter_Header Files_GUID_CMAKE:INTERNAL=95DC9C88-3C17-418B-9331-58A616C8DD01
//Stored GUID
SG_Filter_Resources_GUID_CMAKE:INTERNAL=8288AFBC-B1A5-46BA-A231-C47FBE9784A2
//Stored GUID
SG_Filter_Source Files_GUID_CMAKE:INTERNAL=9C1EB9F8-ACD6-4BEF-BCF7-C3E008220BC1
//Stored GUID
ZERO_CHECK_GUID_CMAKE:INTERNAL=357DB70D-FC06-4BFD-B4DA-E734858450FD
//Stored GUID
astyle_GUID_CMAKE:INTERNAL=BFDE37A6-2C69-4C1E-AF93-9672BFC7F7D4
//Stored GUID
coordinatecaptureplugin_GUID_CMAKE:INTERNAL=7D991F87-ED73-4D2E-BA2B-0F15113CFAE4
//Stored GUID
copyrightlabelplugin_GUID_CMAKE:INTERNAL=1A9216BD-54B8-4A4E-B51E-1E47C8C9CD80
//Stored GUID
delimitedtextplugin_GUID_CMAKE:INTERNAL=7408FCB6-45D8-4C60-9B82-B276DDECCE49
//Stored GUID
delimitedtextprovider_GUID_CMAKE:INTERNAL=95099962-C221-4F68-AA81-0AB8ACED9A0B
//Stored GUID
diagramoverlay_GUID_CMAKE:INTERNAL=6196E7D9-C1CE-4B76-8A69-F9E93A9655D4
//Stored GUID
displacementplugin_GUID_CMAKE:INTERNAL=A3BDAEEA-7354-430F-9F26-E41AC673A6CF
//Stored GUID
dxf2shpconverterplugin_GUID_CMAKE:INTERNAL=4ADBE3F2-AEBF-43E0-8419-B48EC74B00D8
//Stored GUID
evis_GUID_CMAKE:INTERNAL=DA1AB6B9-9C80-415A-8E19-A7BF3E995A93
//Stored GUID
gdalprovider_GUID_CMAKE:INTERNAL=5F13AE2A-E0C5-415D-ABD3-F4FB05F1042F
//Stored GUID
grassplugin_GUID_CMAKE:INTERNAL=B80AD914-DD50-4999-8193-75E99079CF93
//Stored GUID
grassprovider_GUID_CMAKE:INTERNAL=49DA0A4D-FBD9-4683-B2FE-3E0A4D25ABBE
//Stored GUID
grassrasterprovider_GUID_CMAKE:INTERNAL=2935D309-CE66-440B-A133-F09CEFC9ED69
//Stored GUID
interpolationplugin_GUID_CMAKE:INTERNAL=832B4D31-1760-4799-99E8-E78064DEA82E
//Stored GUID
memoryprovider_GUID_CMAKE:INTERNAL=163B7D8B-5E10-45D6-921F-7CB6C9BAA73B
//Stored GUID
northarrowplugin_GUID_CMAKE:INTERNAL=2B0297E3-9EB0-49B5-8AB2-AE074081B7C6
//Stored GUID
offlineeditingplugin_GUID_CMAKE:INTERNAL=C28A71CD-3425-4430-A615-ED459D212455
//Stored GUID
ogrprovider_GUID_CMAKE:INTERNAL=43C5BC0B-CFEC-4F8B-97B2-07401934A0FE
//Stored GUID
oracleplugin_GUID_CMAKE:INTERNAL=75D81C61-00FD-434D-85F3-1AFE5230A4CC
//Stored GUID
osmprovider_GUID_CMAKE:INTERNAL=012A961D-3FF2-49A6-A34D-E7A31550B546
//Stored GUID
postgresprovider_GUID_CMAKE:INTERNAL=860A433A-C1C5-4173-88B5-7CFBE2354091
//Stored GUID
qgis.d.rast_GUID_CMAKE:INTERNAL=778C9A56-4861-4E86-A553-FA31DBEE4AC9
//Stored GUID
qgis.g.browser_GUID_CMAKE:INTERNAL=0A77F6D7-845A-4D0E-9585-B963FEC536E7
//Stored GUID
qgis.g.info_GUID_CMAKE:INTERNAL=AEA98508-8A43-4C0B-86CA-A9F73B14E41B
//Stored GUID
qgis_GUID_CMAKE:INTERNAL=5DF8287B-44C2-415D-A303-44128DC37CDF
//Stored GUID
qgis_analysis_GUID_CMAKE:INTERNAL=C9936598-D302-4B56-AE2F-0B221E00161D
//Stored GUID
qgis_core_GUID_CMAKE:INTERNAL=625A91B6-152B-4FC0-8619-AEDACC669DF9
//Stored GUID
qgis_gui_GUID_CMAKE:INTERNAL=092DF805-7E4F-4C89-BB48-ED24A432C3F6
//Stored GUID
qgis_help_GUID_CMAKE:INTERNAL=634F6491-BF8C-4653-9130-80FAB9EA03FF
//Stored GUID
qgis_mapserv.fcgi_GUID_CMAKE:INTERNAL=68A7116C-132F-4E97-87BD-5B563E1CB82D
//Stored GUID
qgisgrass_GUID_CMAKE:INTERNAL=7BA094AE-33BB-4348-853E-9BF7C666FA54
//Stored GUID
qgissqlanyconnection_GUID_CMAKE:INTERNAL=8CF39BB7-21D9-48E6-A8ED-6D4E16762DDE
//Stored GUID
rasterterrainplugin_GUID_CMAKE:INTERNAL=A68A37A1-6D95-43F8-A9E6-D402807BD78C
//Stored GUID
roadgraphplugin_GUID_CMAKE:INTERNAL=4905921A-5BB7-4BAB-B9FC-5E93A5FAD33C
//Stored GUID
scalebarplugin_GUID_CMAKE:INTERNAL=79E56625-F4B1-472D-8BCF-A49F2CDEEFD8
//Stored GUID
spatialiteprovider_GUID_CMAKE:INTERNAL=3B5EB994-26FF-4535-B803-EAC5FC8E61AA
//Stored GUID
spatialqueryplugin_GUID_CMAKE:INTERNAL=6BAD9BA0-1829-46E6-BF09-3AC5FB8D1A94
//Stored GUID
spitplugin_GUID_CMAKE:INTERNAL=75BE5752-6C0B-49CD-9EB8-C1C14019DB78
//Stored GUID
sqlanywhereplugin_GUID_CMAKE:INTERNAL=79A9728A-999A-4787-9972-C57BB46B2744
//Stored GUID
sqlanywhereprovider_GUID_CMAKE:INTERNAL=0D030998-0C87-4179-B77A-DB8284B66219
//Stored GUID
svnversion_GUID_CMAKE:INTERNAL=E497EE73-09D4-4B32-BFED-6ACA6CFE55C4
//Stored GUID
translations_GUID_CMAKE:INTERNAL=813A0337-C2D7-44B1-B860-A347A37C56E8
//Stored GUID
ui_GUID_CMAKE:INTERNAL=913C9B18-7817-466F-B882-16F152EC48A3
//Stored GUID
uninstall_GUID_CMAKE:INTERNAL=B772CF7B-9F69-47D3-A70E-B182371BF3D5
//Stored GUID
wmsprovider_GUID_CMAKE:INTERNAL=342EB722-75D0-4741-8A57-2514D1CBD38B
