[Qgis-developer] Re: Error_while _Compiling _Qgis_using _MSVC
Tim Sutton lists at linfiniti.com
Tue May 10 10:05:33 EDT 2011
Hi Sunil
On Tue, May 10, 2011 at 3:56 PM, sttsx <ssolak at tai.com.tr> wrote:
> Add "C:\Program Files\GnuWin32\bin" to your PATH environment variable.
Are you sure you are following recent instructions? Use the INSTALL
document in the top of the source tree and go through the procedure
there step by step. All the questions you have had so far should be
covered if you follow the notes carefully.
Best regards
Tim
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-while-Compiling-Qgis-using-MSVC-tp6347394p6347916.html
> Sent from the qgis-developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
