Hi all. If I select 0 as NULL in raster properties, the value on the map is still the original one (you can check with Value Tool, or querying a point), not a NULL. This is a regression from previous behaviour. Anyone confirms? All the best. -- Paolo Cavallini: http://www.faunalia.it/pc
