[Qgis-developer] Qgis standalone app,
sip version and API problems under mac os x
William Kyngesburye
woklist at kyngchaos.com
Wed May 11 10:22:46 EDT 2011
Well, my package is supposed to work on its own (with my frameworks). It should not be trying to use an external SIP/PyQt.
Are you trying to import from within a QGIS python console (QGIS running) or from a Terminal (no QGIS running)?
On May 11, 2011, at 2:54 AM, Luca Mandolesi wrote:
> On Wed, May 11, 2011 at 12:56 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> PyQt must be compiled again for the updated SIP - it still wants the older SIP. But it's odd that QGIS was built for v8, then at runtime finds an *older* v7.
> So, I must try to re-build pyQt?
> Are you building your own QGIS or using my package? If building your own, it's best to bundle Qt/PyQt by setting "-D QGIS_MACAPP_BUNDLE=1" from cmake
> Hi William, I'm using your frameworks version.
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
All generalizations are dangerous, even this one.
