[Qgis-developer] Qgis standalone app,
sip version and API problems under mac os x
William Kyngesburye
woklist at kyngchaos.com
Wed May 11 10:59:59 EDT 2011
There is some info in the readme about this. Set PATH and PYTHONPATH so the QGIS stuff can be found. Though maybe you're doing this already since it does find qgis.core. The important part is that the QGIS path is at the top of the sys.path list, so python finds the bundled pyqt before any pyqt installed in site-packages.
There should be no need to copy anything to inside QGIS. site-packages is just another search path for Python to find things.
On May 11, 2011, at 9:44 AM, Luca Mandolesi wrote:
> On Wed, May 11, 2011 at 4:22 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Well, my package is supposed to work on its own (with my frameworks). It should not be trying to use an external SIP/PyQt.
> Are you trying to import from within a QGIS python console (QGIS running) or from a Terminal (no QGIS running)?
> Yes William, I'm trying to import qgis.core into a standalone app, outside QGis, using for testing the python IDLE.
> P.S.: Also in Qgis 1.7 to use a python module not included into your distribution, it's necessary to copy the module from the site-packages of python framework within the python resources of Qgis.app?
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
