[Qgis-developer] Build problems in qgis1.7.0
sailmcm sailmcm at yahoo.com
Mon May 16 19:07:03 EDT 2011
Unless you have a licensed version of visual studio, use 2008 visual c++ express.  Follow the guide to the letter and it will work.
Maaza
Mert TAS <mert.tas at gmail.com> wrote:
>Hello,
>I am trying to build the qgis1.7.0 from source on Windows. I am using VS
>2005.
>I followed the steps listed in "Building QGis From Source". When I start the
>build
>process with "RelWithDebugInfo" configuration settings it generates the
>following errors:
>1. When it tries to build the python plugings (fTools_tools,
>GdalTools_tools, mapserver_export, osmplugin & plugin_installer)
>in the qgis-trunk\build\python\plugins directory it gives the following
>error for each plugin:
>Error result 1 returned from 'C:\Windows\system32\cmd.exe'
>2. Also when building the "compile_python_files" project it gives the
>following error:
>A tool returned an error code from "Performing Post-Build Event..."
>When I remove the Command Line parameters in the compile_python_files
>Project Properties -> Conf. Properties -> Build Events -> Post-Build Event
>The above error dissapears. But is it true to remove these command line
>parameters
>(They are about cmaking various .py files)
>What should I do to solve these build errors? All help will be appreciated.
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-developer
