[Qgis-developer] Exception "Access Violation No RTTI- Data!" on
windows XP (32 bit)
maaza mekuria
sailmcm at yahoo.com
Tue May 24 00:19:31 EDT 2011
I tried two plugins with a slightly different cose and and I get the same response. I wish it would go away, but wishing does not help here. So I need your expert help.
I find that the canvas object (QgisInterface pointer) loses its data as it passes the layers to processing method. What could cause this? I know the same sort of code works for a single layer data. Any ceiling it has reached? Did I hit the stone/steel wall or am I in need of training. I wish there was an ebook or something that explains these challenges. It would have made my work easier. But I have to be a sleuth and try to find a work around this glass ceiling.
Any ideas, suggestions?
Maaza
--- On Mon, 5/23/11, maaza mekuria <sailmcm at yahoo.com> wrote:
Subject: [Qgis-developer] Exception "Access Violation No RTTI- Data!" on windows XP (32 bit)
To: "qgis-dev" <qgis-developer at lists.osgeo.org>
Date: Monday, May 23, 2011, 3:45 PM
I am getting the error "Access Violation No RTTI- Data!" while I am running my C++ plugin. I checked out on the web to see what if it was reported by anyone, and I found some references about a year ago. I am not sure if any of you have come across of the same and know why it is due to. The plugin does not crash but I am not able to find out what is causing it. I am opening multiple layer data using the layer data providers (shape file layers on the canvas.) and nothing more unusual.
The web problems were reported about a year ago and I can not see what was the resolution except the new version seemed to take of it.
Thank you,
Maaza
-----Inline Attachment Follows-----
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110523/0fc2c907/attachment.html
