[Qgis-developer] DBManager plugin for QuantumGIS (GSoC 2001)
Giuseppe Sucameli
brush.tyler at gmail.com
Tue May 24 03:07:57 EDT 2011
Hi Radim,
On Tue, May 24, 2011 at 7:46 AM, Radim Blazek <radim.blazek at gmail.com>wrote:
> First of all, IMO, the DBManager has to be implemented in QGIS core,
> not as a plugin for two main reasons:
1) it is core functionality
I not agree, it's a GUI functionality. We can implement all the core stuff
in the
qgis core creating API for reuse of code (I think about connections, as it
was done
in WMS provider) and then accessing that from the plugin, but I don't like
the idea
to have DBManager in C++.
> 2) connection factories MUST go to providers, otherwise you start to
> create a set of plugins for each DB, parallel to providers.
I agree with you about this point, as you can see I added yesterday the
QgsDataItem section to the wiki.
>From UI point of view, I would prefer to have everything in one place,
> that means in QBrowser. We can rename QBrowser to QManager and
> suddenly it sounds more logical.
QBrowser is a standalone application, a C++ application, I think the manager
should
be easily maintainable and IMHO python code is the best solution.
Having everything in one tree will
> allow in future to easily drag-and-drop for example Shapefile to
> PostGIS and so on.
That is not a problem, that feature could be implemented in providers, an
import
method which take a QgsMapLayer (this was in my gsoc proposal yet), but have
everything in core without any real and strong reason could make the core
code
hard to maintain.
We have to add support for other providers to
> QBrowser anyway. It does not make sense to have another similar UI
> just for databases, implemented in a different way. Currently QBrowser
> is a stand alone application but it will be integrated also to QGIS
> main application.
QBrowser it's implemented as a C++ standalone application to browse files
and
show information about layers, but those are the same infos you can get
using QGis.
The manager would make easy the use of databases in QGis, but not for QGis
use
only. Ok, we can show preview, load a layer in canvas, but also run queries,
create/edit/drop tables and views, ... pretty different from the QBrowser
aim!
I think all the qgis-devs should say their opinion about this question
raised by Radim.
I attended the GSoC 2009 for a different FOSS project and after I started to
work
on my _accepted_ project all devs said me that they didn't like my project,
so my
code was set aside and left on a branch and my GSoC was set as failed even
if I had
ended coding = no gsoc shirt :'( and no money for the second coding period
I don't want to work again on something that devs don't like,
so please devs, I need your opinion. Thanks.
Regards.
QgsDataItem probably is not the best place where db connections should
> be implemented, but it is good place where they can be used to
> represent databases in QgsBrowserModel and thus in QBrowser. I can
> imagine a QgsDatabase inherited by QgsPostGis, QgsSqlite etc. with all
> the methods you list on [2]. Then a single QgsDatabaseItem (which
> would inherit from QgsDataItem) could represent any DB provider,
> taking as parameter a QgsDatabase child for specific provider.
> Radim
> On Mon, May 23, 2011 at 5:21 PM, Giuseppe Sucameli
> <brush.tyler at gmail.com> wrote:
> > Hi all,
> > I'm starting to work on DBManager plugin for QuantumGIS.
> > I've just created the repository on GitHub [1] and here's [2] a page on
> the
> > QGis wiki
> > containing ideas I wrote in the past few days. I will add weekly reports
> to
> > that wiki page.
> > Any comments and reviews are very welcome.
> > Regards.
> > [1] http://github.com/brushtyler/db_manager
> > [2] http://www.qgis.org/wiki/DB_Manager_plugin_GSoC_2011
> > Giuseppe Sucameli
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110524/2efcc984/attachment-0001.html
