[Qgis-developer] Different Label engines in Qgis not speaking
with each other?
Richard Duivenvoorde
rdmailings at duif.net
Wed May 25 02:44:05 EDT 2011
On 05/25/2011 08:20 AM, Marco Hugentobler wrote:
> The 'abc' labelling is the new labelling engine and it's planned to remove the
> old one (the one that currently is in the vector prop. dialog) soon.
ok, thanks, and apparently they are completely independent, I see now...
The reason the label color was not changing in my test was just because
I was looking at the 'old' labeling engines labels and changing
properties of the new labeling without seeing them: I did not yet choose
one of the attribute names in the 'Field with labels' dropdown (and... I
did not check the checkbox 'Label this layer' immediately ...)
My view as a (monkey)user:
- IF a user pushes the [ABC] button, please initialise the dialog with
'Label this layer' checked, and the first item of the 'Field with
labels' chosen.
In this way you are at least aware that (at the moment) there are two
labelling engines, AND you see labels immediately without too much clicking
Regards,
Richard
