[Qgis-developer] DBManager plugin for QuantumGIS (GSoC 2001)
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed May 25 03:49:10 EDT 2011
Hi Giuseppe
> What I don't like it's to create DBManager as a C++ plugin or just as a
> QBrowser
> extension
Why not integrate the gui into QBrowser? From a user point of view, it is
easier to manage the datasources with one application instead having one for
files, one for databases, one for webservices. I'm not as deep into the topic
as Martin or Radim (but you asked for the opinions of all devs).
> Python code is easily maintainable, furthermore the
> QBrowser/DBManager
> won't do heavy computation, so is there a good reason to develop it using
> C++
> instead of python?
C++ is even more easily maintainable :-). We have a lot of useful functions in
python plugins that would have been integrated into app/analysis/core/gui if
they were written in C++.
Is there a good reason to develop in python? The great benefit of python code
is that you can easily share plugins without the need to compile on every
platform. But in the case of QBrowser, it is already in the source tree, so no
problems with distribution.
Just my 2 cents. It's ultimately your mentor (Martin) that has to decide.
Regards,
Marco
Am Dienstag, 24. Mai 2011, 18.05:46 schrieb Giuseppe Sucameli:
> Hi Marco,
> On Tue, May 24, 2011 at 5:05 PM, Marco Hugentobler <
> marco.hugentobler at sourcepole.ch> wrote:
> > Similar to Radim, I'd prefer to have an integration with QBrowser and its
> > model.
> as I wrote, it's ok for me to use the QgsBrowserModel and QgsDataItem to
> create the tree,
> in fact I added it to the wiki yesterday.
> I also want to improve providers adding the import layer functionality to
> allow to
> move/copy layers between different providers and I had wrote that to my
> proposal.
> QBrowser
> extension. Python code is easily maintainable, furthermore the
> QBrowser/DBManager
> C++
> instead of python?
> Regards.
> Since the browser classes are in the source tree, they are easy to
> > distribute
> > also as C++ code.
> > Regards,
> > Marco
> > Am Dienstag, 24. Mai 2011, 09.07:57 schrieb Giuseppe Sucameli:
> > > Hi Radim,
> > > On Tue, May 24, 2011 at 7:46 AM, Radim Blazek <radim.blazek at gmail.com
> > >wrote:
> > > > First of all, IMO, the DBManager has to be implemented in QGIS core,
> > > > not as a plugin for two main reasons:
> > > 1) it is core functionality
> > > I not agree, it's a GUI functionality. We can implement all the core
> > stuff
> > > in the
> > > qgis core creating API for reuse of code (I think about connections, as
> > it
> > > was done
> > > in WMS provider) and then accessing that from the plugin, but I don't
> > like
> > > the idea
> > > to have DBManager in C++.
> > > > 2) connection factories MUST go to providers, otherwise you start to
> > > > create a set of plugins for each DB, parallel to providers.
> > > I agree with you about this point, as you can see I added yesterday the
> > > QgsDataItem section to the wiki.
> > > >From UI point of view, I would prefer to have everything in one place,
> > > > that means in QBrowser. We can rename QBrowser to QManager and
> > > > suddenly it sounds more logical.
> > > QBrowser is a standalone application, a C++ application, I think the
> > > manager should
> > > be easily maintainable and IMHO python code is the best solution.
> > > Having everything in one tree will
> > > > allow in future to easily drag-and-drop for example Shapefile to
> > > > PostGIS and so on.
> > > That is not a problem, that feature could be implemented in providers,
> > > an import
> > > method which take a QgsMapLayer (this was in my gsoc proposal yet), but
> > > have
> > > everything in core without any real and strong reason could make the
> > > core code
> > > hard to maintain.
> > > We have to add support for other providers to
> > > > QBrowser anyway. It does not make sense to have another similar UI
> > > > just for databases, implemented in a different way. Currently
> > > > QBrowser is a stand alone application but it will be integrated also
> > > > to QGIS main application.
> > > QBrowser it's implemented as a C++ standalone application to browse
> > > files and
> > > show information about layers, but those are the same infos you can get
> > > using QGis.
> > > The manager would make easy the use of databases in QGis, but not for
> > QGis
> > > use
> > > only. Ok, we can show preview, load a layer in canvas, but also run
> > > queries,
> > > create/edit/drop tables and views, ... pretty different from the
> > > QBrowser aim!
> > > I think all the qgis-devs should say their opinion about this question
> > > raised by Radim.
> > > I attended the GSoC 2009 for a different FOSS project and after I
> > > started to work
> > > on my _accepted_ project all devs said me that they didn't like my
> > project,
> > > so my
> > > code was set aside and left on a branch and my GSoC was set as failed
> > even
> > > if I had
> > > ended coding = no gsoc shirt :'( and no money for the second coding
> > period
> > > I don't want to work again on something that devs don't like,
> > > so please devs, I need your opinion. Thanks.
> > > Regards.
> > > QgsDataItem probably is not the best place where db connections should
> > > > be implemented, but it is good place where they can be used to
> > > > represent databases in QgsBrowserModel and thus in QBrowser. I can
> > > > imagine a QgsDatabase inherited by QgsPostGis, QgsSqlite etc. with
> > > > all the methods you list on [2]. Then a single QgsDatabaseItem
> > > > (which would inherit from QgsDataItem) could represent any DB
> > > > provider, taking as parameter a QgsDatabase child for specific
> > > > provider.
> > > > Radim
> > > > On Mon, May 23, 2011 at 5:21 PM, Giuseppe Sucameli
> > > > <brush.tyler at gmail.com> wrote:
> > > > > Hi all,
> > > > > I'm starting to work on DBManager plugin for QuantumGIS.
> > > > > I've just created the repository on GitHub [1] and here's [2] a
> > > > > page
> > on
> > > > the
> > > > > QGis wiki
> > > > > containing ideas I wrote in the past few days. I will add weekly
> > > > > reports
> > > > to
> > > > > that wiki page.
> > > > > Any comments and reviews are very welcome.
> > > > > Regards.
> > > > > [1] http://github.com/brushtyler/db_manager
> > > > > [2] http://www.qgis.org/wiki/DB_Manager_plugin_GSoC_2011
> > > > > Giuseppe Sucameli
> > > > > _______________________________________________
> > > > > Qgis-developer mailing list
> > > > > Qgis-developer at lists.osgeo.org
> > > > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Dr. Marco Hugentobler
> > Sourcepole - Linux & Open Source Solutions
> > Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> > marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> > Technical Advisor QGIS Project Steering Committee
