[QGIS-OSSIM] [Qgis-developer] Integrating OSSIM with QGIS
Norman Vine nhv at cape.com
Wed May 25 22:26:54 EDT 2011
Peter
I would be tempted to use the relatively new OssimSingleImageChain
as the basis for the QGisOssimImageProvider as it seems to map
relatively well to Radim's Raster Provider abstaction
Cheers
Norman
On May 25, 2011, at 4:07 PM, Peter Borissow wrote:
> Hi Tim-
>   We are playing with 1.6. We'll download the 1.7 branch right away. I agree, use of gdal should be abstracted away into a gdal provider. Sounds like we would create an OSSIM provider.
> And yes, we want to create/execute OSSIM image chains directly in QGIS!
> Thanks,
> Peter
> -----Original Message-----
> From: Tim Sutton [mailto:lists at linfiniti.com]
> Sent: Wednesday, May 25, 2011 4:03 PM
> To: Pirmin Kalberer
> Cc: qgis-developer at lists.osgeo.org; Peter Borissow; qgis-ossim at lists.sourceforge.net; Mingjie Su; Harsh Govind
> Subject: Re: [Qgis-developer] Integrating OSSIM with QGIS
> Hi Peter
> 8<-------------------snip----------------------
>>>> We started our investigation late last week. We have a debug version
>>>> of QGIS up and running in Visual Studio 10 (64 bit) using QT 4.7.3. We
>>>> have since discovered how integral GDAL is to QGIS. Undaunted, we
>>>> added a some temporary hacks to bypass GDAL and we're now getting
>>>> images to display via OSSIM! For us, this is a huge first step and we
>>>> are seriously considering pressing ahead.
> What version are you building against? Since the 1.7 branch and in
> current master branch, Radim Blazek has done a great overhaul to cater
> for proper raster providers. That means you should not find QGIS is
> heavily intertwined with GDAL - the use of gdal should be abstracted
> away into the gdal provider, and you should be able to implement ossim
> raster support as a clean separate provider.
> I would also really love to see OSSIM support in QGIS (and maybe some
> of those nice processing chains making their way into QGIS :-).
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> vRanger cuts backup time in half-while increasing security.
> With the market-leading solution for virtual backup and recovery,
> you get blazing-fast, flexible, and affordable data protection.
> Download your free trial now.
> http://p.sf.net/sfu/quest-d2dcopy1
> QGIS-OSSIM mailing list
> QGIS-OSSIM at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/qgis-ossim
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110525/13920029/attachment.html
