[Qgis-developer] Re: MXD
Duarte Carreira
DCarreira at edia.pt
Fri May 27 06:15:18 EDT 2011
Yes, it will be possible ;)
In the meanwhile you can see a short howto here:
http://gis.stackexchange.com/questions/240/is-it-possible-to-connect-to-arcsde-using-quantumgis
I only just now noticed a typo in that post. When I mention an ovr file, I meant a vrt file!! (damned pea brain)
Duarte
-----Mensagem original-----
De: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
Enviada: sexta-feira, 27 de Maio de 2011 11:18
Para: Duarte Carreira
Cc: qgis-developer at lists.osgeo.org
Assunto: RE: [Qgis-developer] Re: MXD
Hi Duarte,
> Although I have been able to get ArcSDE support working in
> QGIS through OGR (it takes forever to connect,
> but afterwards it's quite good while drawing and querying).
would be possible to add your notes on how to do this in the qgis wiki
so they can be eventually be added to the documentation?
Cheers!
-- Giovanni --
