[Qgis-developer] expression-based labelling: multiline problem
Paolo Cavallini
cavallini at faunalia.it
Tue Nov 1 04:08:13 EDT 2011
Il 31/10/2011 23:50, Nathan Woodrow ha scritto:
> Paolo,
> Did you make sure you you had multiline labels ticked in the advanced tab of the
> label options. If you grab the latest build it should be enabled by default now as
> per the pull request of mine Martin just merged.
OK, that way it works - thanks a lot.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
