[Qgis-developer] Problems in actions on MacOS
William Kyngesburye
woklist at kyngchaos.com
Tue Nov 1 09:43:30 EDT 2011
On Nov 1, 2011, at 6:47 AM, Paolo Cavallini wrote:
> Hi all.
> The following action on MacOS:
> /Applications/Safari.app/Contents/MacOS/Safari http://www.google.it/search?q=%PROVINCIA
> is returning in the browser
> file:///Applications/http:/www.google.it/search%3Fq=SI
> instead of the expected
> http:/www.google.it/search?q=SI
> Any explanation?
> Thanks.
The way to run/activate an application with a parameter on OS X is to use the open command. You specify the application by name with the -a flag. So:
open -a Safari http://www.google.it/search?q=%PROVINCIA
The simpler version, if you want to open an URL with the default browser, is to simply 'open' the URL.
It's possible Safari interprets parameters differently when run the *nix way by using the executable, most OS X applications are not made to take parameters this way.
But also, running an app the *nix way creates a new process - you get another icon in your Dock if one is running already, instead of opening a new window in an already-running app.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
