[Qgis-developer] Expression based labeling
Nathan Woodrow
madmanwoo at gmail.com
Wed Nov 2 09:28:28 EDT 2011
Got my dev env back up and running and finished exams so I have patched the
code to handle showing direction for multi line labels and removed the
option to toggle multi line labels.
Pull request at: https://github.com/qgis/Quantum-GIS/pull/54
Note: There is also some small UI tweaks to the expression builder in that
request.
- Nathan
On Mon, Oct 31, 2011 at 5:28 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> OK. If there are no objections from anyone else I'll go ahead and
> implement it this way. My HDD with my dev environment died last night so I
> have had to migrate to a new HDD and new install of Mint. Will take me a
> few days to get back into everything as I have an exam tomorrow. Once that
> is over I can get back to programming.
> - Nathan
> On Sun, Oct 30, 2011 at 10:55 PM, Andreas Neumann <a.neumann at carto.net>wrote:
>> Hi Nathan,
>> This would be ok for me. In reality, we are using this direction symbol
>> only with single lines anyway - and what you suggest sounds also good
>> for multiline labels.
>> Thanks again,
>> Andreas
>> On 10/29/2011 08:27 AM, Nathan Woodrow wrote:
>> >> the direction symbol is important for us. We use it to label the
>> direction
>> >> of waste-water pipes. We use them only in single-line labels though.
>> > Would it be an OK solution to add the > to the last line and the < to
>> the
>> > first line.
>> > eg
>> > Line 1
>> > Line 2 >
>> > or
>> > < Line 1
>> > Line 2
>> > At the moment this is the only thing really stopping us from removing
>> the
>> > multiline option and just letting the code handle multilines as the
>> default
>> > action.
>> > - Nathan
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111102/92845086/attachment.html
