[Qgis-developer] nasty bug
Ramon Andiñach
custard at westnet.com.au
Fri Nov 4 20:31:35 EDT 2011
On 05/11/2011, at 04:35 , Marco Hugentobler wrote:
> Hi Giovanni
> OTF-Reprojection to wgs84 with your raster file works for me with current master.
> Regards,
> Marco
> On 04.11.2011 21:16, Giovanni Manghi wrote:
>>> I couldn't view the video, however I added a geotiff in UTM Zone 15N to an empty project with project properties wet to WGS 84 with no problems.
>> Hi Gary,
>> this link points to a geotiff in epsg 3763, not to a video.
>> It may be related to the issue another user reported in the user ML
>> and that I confirmed (adding my reply to the dev mailing list): it
>> seems that with certain projected CRSs the scale goes wild (also with
>> OTFR on). You can replicate the issue with the above raster layer.
In my mind, that error is associated with a problem with the definition of the CRS of the layer.
Until I ran a workaround for AGD/AMG projections, files in the AGD-based projections (e.g. 20351) would fairly consistently bring up that error.
-ramon.
