[Qgis-developer] Re: [Qgis-user] Re: Qgis-user Digest, Vol 69,
Issue 21
Mars Sjoden
marsofearth at gmail.com
Sat Nov 5 22:41:01 EDT 2011
On Sat, Nov 5, 2011 at 6:24 PM, Kurt Springs <ferret_bard at mac.com> wrote:
I haven't gotten that far. How did you load the pyspatialite python plug
> in? Whe I try to run Qspatialite it tells me it can't find pyspatialite.
> I tried to load it via the easy_install method, but it won't install.
> Kurt
Are you on Windows?? 1.7.1? I'm more familiar with Linux or OS X.
On Nov 6, 2011, at 12:00 PM, Mars Sjoden wrote:
> > Has anyone else found the following issue?
> > 1. Using Mac OS X QGIS 1.7.1 - William Kyng.‚s Frameworks (Also
> occurs on QGIS 1.8 Kyng.‚s)
> > 2. Uploading a Medium sized shapefile to QspatiaLite
> > 3. QGIS Layer
> 4. Use VirtualShape Import (*check ON*)
> > * BUG CRASH does not occur when [Use VirtualShape Import] check OFF
> > Reports and SHP:
> > Upload Tables QspatiaLite - Using VirtualShape Import -
> https://docs.google.com/open?id=0B63BcSDiEI_7YzdkM2JkMTctMWRlMS00OWI2LWEwZDgtNDhiYmJhMTg5Yjg4
> > http://www.keepandshare.com/visit/visit_page.php?i=1851910
> Publicly available Shapefile from:
> > http://geobc.gov.bc.ca/ DOWNLOAD -> Free Data -> [Guest Users Enter
> Here] - category:
> > *Configururable Products*
> > *Land and Natural Resources Information > Forests, Grasslands and
> Wetlands*
> > VRI - Forest Vegetation Composite Polygons and Rank 1
> > Mapsheet: 093L047
> > Mars
> Qgis-user mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111105/7cce6d77/attachment.html
