[Qgis-developer] QGIS 2.0 layertree: decoupling logical grouping and the drawing order
Andreas Neumann a.neumann at carto.net
Wed Nov 9 11:26:42 EST 2011
 Next to being a QGIS user, we are also Autodesk users. One feature I
 like in Autodesk which doesn't exist in QGIS is the decoupling of the
 logical grouping (our existing nested hierarchies) from the actual
 drawing order.
 In Autodesk you have two tabs in the layer tree. One tab is for the
 logical grouping, in the other tab you get a flat list of the drawing
 order.
 Use case: you want to logically group layers from different media (say
 all gaz layers, all water layers, all waste-water layers), but in the
 drawing order you first want to draw the polygon features, then the line
 features, then the point features.
 Something to discuss in the Zurich meeting?
 Attached is also the relevant part of the GUI in Autodesk. It is
 german. The "Gruppen" tab means "Groups", the "Zeichnungsreihenfolge"
 tab means "drawing order".
 Do you also think that this decoupling would be useful for upcoming
 QGIS versions?
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111109/39a62022/autodesk_layer_tree_distinction_between_grouping_and_drawing_order-0001.png
