[Qgis-developer] Python: how to set snapping options?
Andreas Neumann
a.neumann at carto.net
Wed Nov 23 11:56:22 EST 2011
Thanks for the pointer Marco!
If I set the Project settings - are the snapping settings automatically
active and ready to use?
Andreas
On Wed, 23 Nov 2011 17:02:29 +0100, Marco Hugentobler wrote:
> Hi Andreas
> It can be done using QgsProject::instance()->writeEntry(...). You may
> look in the class src/app/qgssnappingdialog.cpp how QGIS does it.
> Regards,
> Marco
> On 23.11.2011 14:42, Andreas Neumann wrote:
>> Hi,
>> I'd like to programmatically set the snapping option I just added
>> with my python plugin:
>> * turn on snapping within its own layer
>> * set avoid intersection
>> Does anyone have a hint or code how to accomplish this?
>> Thanks,
>> Andreas
> Qgis-developer mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
