[Qgis-developer] Re: AW: [Qgis-user] Re: Mapbooks with Easyprint
Nathan Woodrow madmanwoo at gmail.com
Fri Nov 25 23:27:03 EST 2011
Ziegler,
Just thought I would let you know.  I added a method a while ago that
will hopefully help making map books using composer layouts a bit easier.
 I added a composer item id which you can assign in the UI and then
reference in the code.  The ID/Name is just a string so you can use any
convention for naming you composer items, any composer item can have a
id/name e.g you could name a map frame "overview" and then reference this
to put the overview window in that map frame; or name a text label "Title"
and then put the map title in there.
The method is called QgsComposerItem::id() and you can get to it using
Python or C++.
Would love to see EasyPrint use composer layouts to generate map books, I
know a lot of users would love it. Hopefully this will help you.
- Nathan
On Fri, Nov 18, 2011 at 3:45 AM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> Il 17/11/2011 17:22, Möri Cedric ha scritto:
>  The templates are stored in a xml file (layouts.xml), which you should
>> find in the plugins directory in your home directory where easyprint is
>> installed.
>> So under linux it's something like  ~/.qgis/python/plugins/**
>> easyprint/layouts/layouts.xml.
> It should be easy to let the plugin read the project print layouts as well.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111126/6f6caaf7/attachment.html
