[Qgis-developer] problems with Identify and select tool
James Stott
James.Stott at npaconsult.co.uk
Tue Nov 29 05:43:30 EST 2011
Has anyone else had problems with the identify and the select tool? They seem to have appeared in the last couple of days as it worked last week.
I get an error message whenever I click on the map with either tool. It does this for every vector layer. It still returns values for the raster layer I am using as background mapping.
I am running 1.9.90.7 OSgeo4W.
The error is as follows:
Query Failed:
1 cursor states lost.
SQL: declare qgisf11 binary cursor for select "gid",asbinary("the_geom",'NDR'),"name"::text,"theme"::text,"themname"::text,"themid"::text,"status"::text,"perimeter"::text,"area"::text,"gridref"::text from "data"."awi" where "the_geom" && setsrid('BOX3D(177120.8977402151504066 59808.3671354566467926, 177233.5664761684311088 59921.0358714099420467)'::box3d,27700) and intersects("the_geom",setsrid('BOX3D(177120.8977402151504066 59808.3671354566467926, 177233.5664761684311088 59921.0358714099420467)'::box3d,27700)))
Result: 7 (ERROR: syntax error at or near ")"
LINE 1: ...33.5664761684311088 59921.0358714099420467)'::box3d,27700)))
James Stott BSc (Hons) MSc | Senior Professional
Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
T: 01225 445548 | M: -
http://www.npaconsult.co.uk/
http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
http://www.npaconsult.co.uk/terms.asp
This Electronic Transmission is intended only for the attention of the addressee. It may contain privileged and confidential information. If you are not the person for whom it is intended, you must not copy, distribute or take any action in reliance on it. If you have received this electronic transmission in error please notify us immediately by telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure that this message and any attachments are free from viruses.
Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0) 01225 445548, Fax: +44 (0) 01225 312387, Website: http://www.npaconsult.co.uk/
