[Qgis-developer] problems with Identify and select tool
Andreas Neumann a.neumann at carto.net
Tue Nov 29 08:36:57 EST 2011
 Thank you for the quick fix ;-)
 Andreas
 On Tue, 29 Nov 2011 13:31:52 +0100, Jürgen E. Fischer wrote:
> Hi,
> On Tue, 29. Nov 2011 at 11:51:48 +0100, Andreas Neumann wrote:
>> yes - I have similar problems.
>> Jürgen is working on it. It is a side effect of recent modifications
>> on
>> the PostgreSQL provider.
> I suppose you're not using the current master ;)
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel.
> +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
> +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
