[Qgis-developer] Benchmarking / optimization
Andreas Neumann
a.neumann at carto.net
Wed Nov 30 07:30:57 EST 2011
I can confirm that performance in a production environment is ok - see
examples at http://gis.uster.ch/
Performance can always be improved, but one also has to keep in mind
that the other two projects (UMN and Geoserver) are specifically
programmed as a map server whereas QGIS server was originally only
Desktop and is quite a bit younger in development history.
The benchmarks also had some quite extreme examples that are not always
common in production environments. But it is good to participate in
these benchmarks to find and detect issues that can lead to performance
improvements.
Andreas
On Wed, 30 Nov 2011 11:54:55 +0100, Marco Hugentobler wrote:
> Hi Luca
> Benchmarks are very specific, it's impossible to create general
> statements just from the slides without knowing the test arrangement
> very well.
> If you are referring to the foss4g benchmark this year, the first
> comparison test was mainly about the performance of near empty
> requests (otherwise, impossible to handle more than 100 requests per
> second also for umn or geoserver).
> In production environments, my impression is that QGIS server is not
> dramatically slower than other WMS servers.
> Regards,
> Marco
> On 30.11.2011 11:35, luca_manganelli at comune.trento.it [4] wrote:
>> qgis-developer-bounces at lists.osgeo.org [1] scritti il 30/11/2011
>> 11.24.23
>> > IMHO:
>> > - it would be easy to setup a test engine for QGIS Server, and
>> keep
>> > updated a table of results, so we could spot promptly any change
>> in
>> > performances
>> > - anyway, QGIS Server should be used as tiled, in any condition
>> where
>> > performance is an issue.
>> > All the best.
>> In a recent WMS comparison presentation (MapServer vs GeoServer vs
>> QGIS server vs others), benchmarks had shown that QGIS server is the
>> worst and doesn't scale with the number of CPU cores.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org [2]
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer [3]
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch [5] http://www.sourcepole.ch [6]
> Technical Advisor QGIS Project Steering Committee
> Links:
> [1] mailto:qgis-developer-bounces at lists.osgeo.org
> [2] mailto:Qgis-developer at lists.osgeo.org
> [3] http://lists.osgeo.org/mailman/listinfo/qgis-developer
> [4] mailto:luca_manganelli at comune.trento.it
> [5] mailto:marco.hugentobler at sourcepole.ch
> [6] http://www.sourcepole.ch
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
