[Qgis-developer] Re: [Qgis-user] Offline editing not working on
some layer types.
Nathan Woodrow
madmanwoo at gmail.com
Thu Oct 13 18:52:45 EDT 2011
It is installed by default with QGIS 1.5+ so it will be in the Plugin
Manager under "offline"
- Nathan
On Fri, Oct 14, 2011 at 8:50 AM, Noli Sicad <nsicad at gmail.com> wrote:
> What exactly the name of this plugin?
> I typed "offline" in the filter for QGIS python plugin installer,
> nothing is showing up.
> Noli
> On 10/14/11, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> > Hi All,
> > I was trying to use the offline editing plugin for some field work but it
> > doesn't seem to want to convert the layers to offline for me.
> > The layers are all MapInfo .TAB files when running convert to offline the
> > plugin sits for a while then goes back to the map canvas. This is the
> > output in my Windows XP DebugView:
> > [6032] d:\src\qgis\src\app\qgscustomization.cpp(778) :
> > (QgsCustomization::customizeWidget) objectName =
> > QgsOfflineEditingPluginGuiBase event type = 17
> > [6032] d:\src\qgis\src\app\qgscustomization.cpp(780) :
> > (QgsCustomization::customizeWidget) QgsOfflineEditingPluginGui x QDialog
> > (QgsCustomization::customizeWidget) objectName = event type = 17
> > (QgsCustomization::customizeWidget) QMessageBox x QDialog
> > QgsOfflineEditingProgressDialogBase event type = 17
> > (QgsCustomization::customizeWidget) QgsOfflineEditingProgressDialog x
> > QDialog
> > [6032] d:\src\qgis\src\core\qgsmaplayer.cpp(53) :
> (QgsMapLayer::QgsMapLayer)
> > lyrname is 'Buildings (offline)'
> > [6032] d:\src\qgis\src\core\qgsmaplayer.cpp(59) :
> > layerName is 'Buildings (offline)'
> > [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(363) :
> > (QgsProviderRegistry::provider) Library name is
> > C:/OSGeo4W/apps/qgis-dev/plugins/spatialiteprovider.dll
> > [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(369) :
> > (QgsProviderRegistry::provider) Loaded data provider library
> > [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(370) :
> > (QgsProviderRegistry::provider) Attempting to resolve the classFactory
> > function
> > [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(377) :
> > (QgsProviderRegistry::provider) Getting pointer to a dataProvider object
> > from the library
> > [6032]
> d:\src\qgis\src\providers\spatialite\qgsspatialiteprovider.cpp(4102)
> > : (QgsSpatiaLiteProvider::SqliteHandles::openDb) New sqlite connection
> for
> > C:/offline.sqlite
> > [6032]
> d:\src\qgis\src\providers\spatialite\qgsspatialiteprovider.cpp(4123)
> > : (QgsSpatiaLiteProvider::SqliteHandles::openDb) Connection to the
> database
> > was successful
> > [6032]
> d:\src\qgis\src\providers\spatialite\qgsspatialiteprovider.cpp(459) :
> > (QgsSpatiaLiteProvider::QgsSpatiaLiteProvider) Invalid SpatiaLite layer
> > [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(388) :
> > (QgsProviderRegistry::provider) Instantiated the data provider plugin
> > [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(389) :
> > (QgsProviderRegistry::provider) provider name: spatialite
> > [6032] d:\src\qgis\src\core\qgsproviderregistry.cpp(399) :
> > (QgsProviderRegistry::provider) Invalid data provider
> > [6032] d:\src\qgis\src\core\qgsvectorlayer.cpp(2843) :
> > (QgsVectorLayer::setDataProvider) unable to get data provider
> > Seems if you do the same with using Shapefiles everything works fine.
> > Anyone had this problem before?
> > - Nathan
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111014/37825d05/attachment.html
