[Qgis-developer] Installed Qgis on Ubuntu - what do I do next?
Christopher Stark christopherstark at gmx.de
Sat Oct 15 06:23:56 EDT 2011
thank you. I did all this but now I get this error message:
This XML file does not appear to have any style information associated
with it. The document tree is shown below.
<ServiceExceptionReport version="1.3.0"><ServiceException
code="ServiceNotSpecified">Service not specified. The SERVICE parameter
is mandatory</ServiceException></ServiceExceptionReport>
Questions below:
Am 14.10.2011 21:50, schrieb Giovanni Manghi:
>> What should I do as first steps after installing?
> if working correctly, the address
> http://localhost/cgi-bin/qgis_mapserv.fcgi
> should return
> code="OperationNotSupported">Please check the value of the REQUEST
> parameter</ServiceException></ServiceExceptionReport>
> Then just create a project in QGIS (use absolute paths) and in the
> project properties configure the parameters in the "WMS server" tab.
which paramenters are important here? What does absolute paths mean in
this regard
> Create a folder in
> /usr/lib/cgi-bin/
> and copy into it your QGIS project and a copy of qgis_mapserv.fcgi
> your server address will be
> http://localhost/cgi-bin/myprojectfolder/qgis_mapserv.fcgi
> cheers
> -- Giovanni --
Best regards
Christopher
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111015/793959c0/attachment.html
