[Qgis-developer] Bison 2.3 error When Building QGIS for Snow Leopard
William Kyngesburye woklist at kyngchaos.com
Sat Oct 15 14:34:53 EDT 2011
I haven't tried compiling since the spatialindex changes.  Looks like I need to...
Or, if you want to get more helpful output from compilation, add this to configuration:
-D CMAKE_VERBOSE_MAKEFILE=true
make will them show you all the compile commands and more detailed errors.
The debug build is (replace the CMAKE_BUILD_TYPE option with this):
-D CMAKE_BUILD_TYPE=Debug
On Oct 15, 2011, at 1:17 PM, Mars Sjoden wrote:
> Interestingly getting errors on make install for qgsspatialindex
> make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgsspatialindex.cpp.o] Error 1
> make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> On Sat, Oct 15, 2011 at 11:06 AM, Mars Sjoden <aurorageomatics at gmail.com> wrote:
> Thank You!
> Amazing how much help you have been.
> How do I build QGIS with Debug=true?  as a side note
> On Sat, Oct 15, 2011 at 11:03 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I found that cmake still uses the system bison even if a different one is first in the PATH.  You need to force cmake to use yours with a configure option:
> -D BISON_EXECUTABLE=/usr/local/bin/bison
> assuming you installed bison 2.4 in /usr/local.
> On Oct 15, 2011, at 12:50 PM, Mars Sjoden wrote:
> > I been running through the Build instructions for QGIS Mac OS X on the QGIS Wiki,
> > ** I remembered to comment out "QwtSVGItem" in the qwtconfig.pri file as it stumbles on finding the x_86_64 framework from the universal framework.
> > However when building QGIS I receive an error that Snow Leopard only has BISON 2.3 and at least 2.4 is needed.
> > I built 2.4.3 Bison but error still throws, unable to find the new Bison build?
> > Just wondering what my next best step is?
> > I would like to build QGIS with debug flag to help find better crash info.
> > Thanks!!
> > Mars
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
