[Qgis-developer] QGIS 1.7.1 Mint 11 Katya... (natty?Ubuntu) -
Symbology Change Randomly Crashes QGIS
Mars Sjoden
aurorageomatics at gmail.com
Sat Oct 15 20:27:55 EDT 2011
I have some Debug info on the Symbology crashing issue I am having on Mac
and Linux.
Here is some info on my Linux Natty build:
QGIS version
1.8.0-Trunk
QGIS code revision
ac923a8
Compiled against Qt
4.7.2
Running against Qt
4.7.2
GDAL/OGR Version
1.8.0
GEOS Version
3.2.2
PostgreSQL Client Version
8.4.8
SpatiaLite Version
2.4.0
QWT Version
5.2.0
This copy of QGIS writes debugging output.
Rule-based renderer:
RULE Highways - scale [0,0] - filter ROAD_CLASS = 'highway' OR ROAD_CLASS =
'arterial' - symbol LINE SYMBOL (2 layers) color 176,176,176,255
RULE Road Paved - scale [1000,100000] - filter RDSRFC = 'paved' and
(ROAD_CLASS != 'highway' OR ROAD_CLASS != 'arterial') - symbol LINE SYMBOL
(2 layers) color 134,67,0,255
RULE Road Gravel - scale [0,0] - filter RDSRFC = 'loose' - symbol LINE
SYMBOL (1 layers) color 0,0,0,255
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgsvectorlayer.cpp: 979:
(draw) attrs: ROAD_CLASS - 20
(draw) attrs: RDSRFC - 21
Debug: /home/mars/dev/cpp/Quantum-GIS/src/providers/ogr/qgsogrprovider.cpp:
763: (select) Setting spatial filter using POLYGON((950459.84366500
1038677.45986962, 950459.84366500 1046082.97714738, 962302.73502300
1046082.97714738, 962302.73502300 1038677.45986962, 950459.84366500
1038677.45986962))
720: (nextFeature) Feature is null
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgsvectorlayer.cpp: 788:
(drawRendererV2) Total features processed 644
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgsmaprenderer.cpp: 501:
(render) Layer rendered without issues
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgsmaprenderer.cpp: 541:
(render) Done rendering map layers
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgscoordinatetransform.cpp:
375: (transformBoundingBox) Entering transformBoundingBox...
423: (transformBoundingBox) Projected extent:
950459.8436649995855987,1038677.4598696234170347 :
962302.7350230009760708,1046082.9771473781438544
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgsvectorlayer.cpp: 327:
(drawLabels) Starting draw of labels
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgspallabeling.cpp: 1061:
(drawLabeling) LABELING work: 0 ms ... labels# 0
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgspallabeling.cpp: 1184:
(drawLabeling) LABELING draw: 0 ms
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgsmaprenderer.cpp: 619:
(render) Rendering completed in (seconds): 3.348
Debug: /home/mars/dev/cpp/Quantum-GIS/src/app/qgslabeldialog.cpp: 337:
(~QgsLabelDialog) entering.
Debug: /home/mars/dev/cpp/Quantum-GIS/src/app/qgslabeldialog.cpp: 42:
(QgsLabelDialog) entering.
Debug: /home/mars/dev/cpp/Quantum-GIS/src/app/qgslabeldialog.cpp: 59: (init)
entering.
entering.
Debug: /home/mars/dev/cpp/Quantum-GIS/src/app/qgscustomization.cpp: 778:
(customizeWidget) objectName = QgsRendererV2PropsDialogBase event type = 17
Debug: /home/mars/dev/cpp/Quantum-GIS/src/app/qgscustomization.cpp: 780:
(customizeWidget) QgsRendererV2PropertiesDialog x QDialog
(customizeWidget) objectName = QgsVectorLayerPropertiesBase event type = 17
(customizeWidget) QgsVectorLayerProperties x QDialog
(customizeWidget) objectName = QgsSymbolV2SelectorDialogBase event type = 17
(customizeWidget) QgsSymbolV2SelectorDialog x QDialog
(customizeWidget) objectName = QgsRendererRulePropsDialog event type = 17
(customizeWidget) QgsRendererRulePropsDialog x QDialog
(customizeWidget) objectName = DlgSymbolV2Properties event type = 17
(customizeWidget) QgsSymbolV2PropertiesDialog x QDialog
Debug: /home/mars/dev/cpp/Quantum-GIS/src/app/qgslabeldialog.cpp: 342:
(apply) entering.
Debug: /home/mars/dev/cpp/Quantum-GIS/src/core/qgsmaplayer.cpp: 104:
(setLayerName) new name is 'DRA_LINESP_line'
Segmentation fault
mars at Mint11 ~ $
I can provide the full Debug output from start if anyone likes. I hope this
will help in whatever small part.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111015/395236af/attachment-0001.html
