[Qgis-developer] Re: Shaded Relief: Memory Error on Windows OS
Andreas Plesch
andreasplesch at netscape.net
Mon Oct 24 11:00:56 EDT 2011
Hello Agus,
the machine is likely running out of memory. The DEM is probably too
large. So you could try cropping down the DEM, use a machine with more
memory or use the built-in shaded relief tool which is more memory
efficient.
Hope this helps,
Andreas
On Sun, Oct 23, 2011 at 6:06 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Students report a Memory Error at running plugin Shaded Relief on
> Windows machines
> with qgis 1.7.1.
> Is there any solution to this problem?
> See picture in
> https://sites.google.com/site/filestemp2/home/shreliefproblem1.png
> Agus
Andreas Plesch
20 Oxford St.
Cambridge, MA 02138
Tel: 617-495-2356
Fax:617-495-7660
