[Qgis-developer] Approximate reprojection for vectors
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Oct 26 02:15:57 EDT 2011
Hi Giovanni
> Martin I just found that you proposed a patch to allow speed up vector
> rendering
> http://hub.qgis.org/issues/3200
> maybe this can be tested again and added in time for 1.8?
Depends when the release should be.
Large modifications of the central core classes shouldn't be merged in short
before a release. Better is to consider it short after a release.
Regards,
Marco
Am Mittwoch, 26. Oktober 2011, 00.45:03 schrieb Giovanni Manghi:
> Hi,
> On Wed, 2011-10-05 at 13:57 +0300, Alexander Bruy wrote:
> > Hi,
> > 2011/10/4 Martin Dobias <wonder.sk at gmail.com>:
> > > In any case we should look into the performance in a more coordinated
> > > way: 1. choose a dataset for testing - ideally just 1-3 layers of real
> > > data with lots of features (e.g. 10000+) for each feature type -
> > > points, polylines, polygons. Any ideas for a free dataset?
> > We have large point shapefile with lots of features [0], also there is
> > a polygonal [1] and lines [2] layers
> > [0] http://gis-lab.info/data/gns/gns-shp-utf-rs.7z
> > [1] http://gis-lab.info/data/rusbounds-rosreestr/regions2010_wgs_shp.7z
> > [2] http://gis-lab.info/data/rusbounds-rosreestr/all_rubounds_wgs_shp.7z
> rendering
> cheers
> -- Giovanni --
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
