[Qgis-developer] Python problem - qgispython.dll
Martin Dobias
wonder.sk at gmail.com
Thu Sep 1 16:37:30 EDT 2011
Hi Sasikumar
On Wed, Aug 31, 2011 at 10:22 AM, Sasikumar Kanniyappan
<qgis.developer at gmail.com> wrote:
> Hello list,
> I have compiled and build the Qgis 1.7 using Visual C++ environment and it
> working fine in my local machine. But,
> after creating the installer and installed in the fresh machine(No
> environment variable set in the fresh machine),
> while start up Qgis 1.7 crashes. Then I removed the qgispython.dll in the
> bin folder, Qgis 1.7 working without any
> issues. I know that Qgis work without python. But I need to enable the
> python plugin.
If you install QGIS 1.7 from the installer on that machine, would it
crash too? If not then you have probably done something wrong when
compiling or preparing the installer.
Btw. what leads you to compile QGIS on windows yourself instead of
using standalone installer or osgeo4w packages?
> I have referred the http://trac.osgeo.org/qgis/ticket/1214 link and followed
> the changes but no uses. Can anyone
That's an old and irrelevant ticket.
Martin
