[Qgis-developer] Native MS SQL 2008 Driver for QGIS
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Sep 5 08:34:12 EDT 2011
Hi Nathan
I also think that a native QGIS provider (subclass of QgsVectorDataProvider)
for MS SQL 2008 would be a great thing. The reason to go for a native driver
(and not via OGR) are the same as with PostGIS:
- performance is better (less conversion)
- even with the OGR driver, it needs work to be done for a good QGIS
integration. E.g. QGIS is strict to have only one shapetype in a layer and it
requires a unique identifiere for a feature (also in a db view)
Btw. a native oracle spatial provider would also be nice to have. Oracle
spatial is (unfortunately) quite common here.
Regards,
Marco
Am Montag, 5. September 2011, 14.05:00 schrieb Nathan Woodrow:
> Hi all,
> There has been some interest from a company here in Australia to develop a
> MS SQL driver/provider for QGIS. IMO this is a good move as most
> local governments, where I work and where I push my QGIS agenda, pretty
> much all use MS SQL 2008 spatial for storing spatial data. Having a
> driver for MS SQL would make QGIS more attractive to these and many more
> Windows users.
> The thing I wanted to find out was if implementing a native/provider MS SQL
> Driver in QGIS would be the correct way to go about this. At current there
> is already a MS SQL driver for OGR, which can be used to open layer from
> the database in QGIS using the Python console. However there is no UI and
> while OGR is fine with opening database connections it seems strange to
> use OGR for some database engines but not others.
> My thoughts were
> Implement a native QGIS driver for MS SQL inheriting from
> - Less program layers as your not going though OGR then wrapping it in
> the QgsFeature class (should be faster).
> - Implement QBrowser support like what Giuseppe has done with his
> improvements to the postgis provider.
> - Closer control over the code eg faster bug fixing and features. Don't
> need to wait for OGR packages to be updated.
> I guess something that came to mind is that we have a native provider for
> PostGIS but yet OGR supports it.
> In my mind a native driver is the way to go as we can integrate it more
> tightly into the QGIS code base and not rely on an other library for bug
> fixes and updates.
> What are other peoples thoughts?
> - NathanW
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
