[Qgis-developer] Vector File Creatioin and documentation
Giuseppe Sucameli
sucameli at faunalia.it
Wed Sep 28 18:39:36 EDT 2011
Hi Maaza,
On Wed, Sep 28, 2011 at 9:48 PM, maaza mekuria <sailmcm at yahoo.com> wrote:
> using an "ESRI Shape File" provider (instead of "ogr") in the
> QgsVectorFileWriter instead of the QgsVectorLayer.
that is not the provider name, but the output format.
QgsVectorLayer doesn't support to create new vector files, even Qgis
uses QgsVectorFileWriter to save shapefiles (and also other vector
file formats).
> The parameters are ill-defined and not properly documented.
The pyQGis cookbook contains snippets of code and well explained
examples (e.g. how to write a shapefile using QgsVectorFileWriter [1]).
Of course those are in python, but the C++ and Python API are
quite the same.
I recommend to have a look at the Qgis API [2], but IMHO many
times the pyQGIS cookbook [3] is the best way to understand how to
use some classes in your code.
> Can we do something to update the documentation?
Yes, you're welcome.
To help us in keeping documentation updated, please look at [4].
Regards.
[1] http://www.qgis.org/pyqgis-cookbook/vector.html#writing-vector-layers
[2] http://doc.qgis.org/head/classes.html
[3] http://www.qgis.org/pyqgis-cookbook/
[4] http://www.qgis.org/en/documentation.html
> --- On Fri, 9/23/11, maaza mekuria <sailmcm at yahoo.com> wrote:
>> From: maaza mekuria <sailmcm at yahoo.com>
>> Subject: [Qgis-developer] Vector File Creatioin
>> To: "QGIS Developer" <qgis-developer at lists.osgeo.org>
>> Date: Friday, September 23, 2011, 3:50 PM
>> I am wondering if I have to do to
>> save the shape files. Below is the code I am using. I am
>> able to create memory layers that I could save later. But I
>> want to create many shapefiles and QGIS started to run out
>> of memory when I was loading the memory shapefiles. Once I
>> change the provider to OGR and give the path and basename,
>> it gets a NULL provider.
>> Can some of the QGIS Master's help a novice?
>> QString mPath = ("c:/tmp/qgis/");
>> QString mBaseName =
>> ("BikeNA");
>> QString
>> provLib="ogr";
>> QgsVectorLayer* vl = 0;
>> vl = new QgsVectorLayer( mPath,
>> mBaseName, provLib );
>> QgsVectorDataProvider *prov =
>> vl->dataProvider();
>> prov->addAttributes(
>> attrList );
>> vl->startEditing();
>> QgsFeature f;
>> featureList::Iterator it;
>> for ( it = featureList.begin(); it !=
>> featureList.end();it++)
>> f = *it;
>> vl->addFeature( f
>> vl->updateExtents();
>> vl->endEditCommand();
>> vl->commitChanges();
>> maaza
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giuseppe Sucameli
