[Qgis-developer] add xcoord, ycoord broken?
Salvatore Larosa
lrssvtml at gmail.com
Tue Apr 3 13:20:26 EDT 2012
Il giorno mar, 03/04/2012 alle 17.00 +0200, Paolo Cavallini ha scritto:
> Il 03/04/2012 16:51, Alexander Bruy ha scritto:
> > Hi,
> > works fine for me
> could you please try with the example attached?
> EPSG:3003
> thanks.
Ciao Paolo,
I did some test to figure out the issue!
The error occurs when the SHP is 3D MultiPoint as in your attached file.
If you convert SHP geometries from 3DMultiPoint to Point, the
calculation of the coordinates works fine!
Hope this helps!
Saluti
-SL
