[Qgis-developer] Benchmarking / optimization
Tim Sutton
lists at linfiniti.com
Sun Apr 8 06:01:04 EDT 2012
Hi
On Sat, Apr 7, 2012 at 9:08 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 06/04/2012 13:00, Radim Blazek ha scritto:
>> To get comparable results, the benchmark must be run on a computer
>> with no or little other load (Linux kernel counts process switching
>> overhead in process time) and CPU parameters must not change
>> frequently (all the data collected are relative).
>> The requirement would be a dedicated time (1-2h per day should be
>> sufficient) on a server with 2 CPU/cores (the second for database in
>> case of db providers).
> So, it may be better to have a dedicated virtual server for this?
> BTW: can we have an overview of the "qgis servers"? How many, which
> services, who is root on which? I think if we need additional resources (as
> this thread implies), we can plan for a consolidation & upgrade, and search
> ad hoc funding for this.
> Thanks.
This is the type of info that needs to go in the QGIS -Governance
docs. But due to all the consolidation work there is only now:
- qgis.org server hosted by OSGEO
- android.qgis.org hosting donated by me
Gary and I used to run much of the project infrastructure on our own
servers but that has pretty much all been rationalised to the servers
above now. Possibly we could ask OSGEO for another vm if needed. We
could also build benchmarks on my server, but it wouldnt be a zero
load environment as Radim suggested.
Regards
Tim
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
