[Qgis-developer] Wrong Area for large polygons in vector/Geometry
Tools/Export/Add Geometry Columns
Agustin Lobo
alobolistas at gmail.com
Mon Apr 9 11:14:54 EDT 2012
ok, it seems there are 2 issues here:
1. The wrong results I get with
vector/Geometry Tools/Export/Add Geometry Columns
that are just missing digits to the right for large numbers
Giovanni: which version are you using?
2. The fact that results provided by R are so different. The most
intriguing/worrying is
that the R results are using package sp and package Rgeos.
I'm dealing with Edzer Pebesma regarding this issue in R-sig-geo and
will keep the list
informed. Perhaps I will open a new ticket on this specific subject
but lets wait
to see what Edzer says.
Agus
El día 9 de abril de 2012 14:35, Giovanni Manghi
<giovanni.manghi at gmail.com> escribió:
>> Check, for example, polygons with ID 25967 and 26570: according to the table,
>> the areas are
>> 25967: 8550196769
>> 26570: 1736474738
>> while visual inspection indicates that 26570 is obviously much larger.
> this depends on
> http://hub.qgis.org/issues/4955
> if you compute areas (with both the filed calculator or the "add
> geometry columns tool") you get
> ID Area_FC
> 25967 8550196769.93
> 26570 173647473841.47
> that makes sense according to the size of polygons
>> Both results are different than those calculated by R:
>> 25967: 9294889613
>> 26570: 205414657947
>> Discrepancies with R are particularly large for polygons with area > 1E+10
> Can't understand these differences.
> -- Giovanni --
> Qgis-developer mailing list
