[Qgis-developer] Tests failing
Tim Sutton lists at linfiniti.com
Fri Apr 13 06:58:45 EDT 2012
Hi
On Fri, Apr 13, 2012 at 7:46 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Hi all.
> In my case, with current master:
>      Start  4: qgis_regression992
>  4/17 Test  #4: qgis_regression992 ...................***Failed    9.28 sec
>      Start  6: qgis_rasterlayertest
>  6/17 Test  #6: qgis_rasterlayertest .................***Failed    2.97 sec
>      Start  9: qgis_rendererstest
>  9/17 Test  #9: qgis_rendererstest ...................***Failed    4.82 sec
>      Start 12: qgis_coordinatereferencesystemtest
> 12/17 Test #12: qgis_coordinatereferencesystemtest ...***Failed    1.94 sec
Can you run it with 'make check' and provide the detailed log it provides?
Also useful for diagnostics are:
* /tmp/*_diff.png, providing any of these that have red in them.
* the versions of gdal, proj, geos etc that your qgis is linked to.
Thanks
Tim
> All the best.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
