[Qgis-developer] Sextante: SAga ERRORS
Salvatore Larosa
lrssvtml at gmail.com
Fri Apr 13 12:18:14 EDT 2012
Il giorno ven, 13/04/2012 alle 17.14 +0200, Paolo Cavallini ha scritto:
> Hi all.
> Running slope, aspect etc results in:
> Could not load
> layer: /home/paolo/sextante/tempdata/1334329842.3813.tif
> Check the SEXTANTE log to look for errors in algorithm execution
Ciao Paolo,
It is an error in quote string, I get this in log:
Syntax error: Unterminated quoted string
So, if you change in SagaAlgorithm.py (line 238) file:
commands.append("libio_gdal 1 -GRIDS \"" + filename2 + "\" -FORMAT 1
-TYPE 0 -FILE " + filename + "\"");
to:
-TYPE 0 -FILE \"" + filename + "\"");
It should work, for me it is!
Cheers,
-SL
