[Qgis-developer] [WebClient] rule-based style SLOW
bernhard.stroebl at jena.de
Thu Apr 19 09:26:03 EDT 2012
Hi Martin,
thank you for the reply
Am 19.04.2012 14:36, schrieb Martin Dobias:
> On Thu, Apr 19, 2012 at 12:00 PM,<bernhard.stroebl at jena.de> wrote:
>> Hi,
>> I realized that using a rule-based style makes the client dead slow.
>> Normally the log shows a timeout on the server for qgis_mapserv.fcgi. If I
>> put the rules into the data source (postgres) and use a categorized style
>> the client performs as expected. The slowliness can only be experienced when
>> zooming or panning.
>> I prepared an example (will be probably removed in a couple weeks):
>> http://map2.jena.de/kartenportal/test?format=image/png&visibleLayers=Stadtplan&lang=en
>> after loading please activate one of the layers and zoom in on the colored
>> area in the south
>> rule-based style: loads forever (Navigation history brings you back)
>> categorized style: loads ok
> Is it slow also in QGIS desktop app or is it something specific to the
> QGIS server?
desktop is fast
and so is QGIS server; compare
http://map2.jena.de/wms/test?LAYERS=Stadtplan%2Ccategorized%20style&FORMAT=image%2Fpng&DPI=96&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A31468&BBOX=4470654.5050516,5638947.4195052,4471988.6271692,5639432.5548208&WIDTH=1012&HEIGHT=368
and
http://map2.jena.de/wms/test?LAYERS=Stadtplan%2Crule-based%20style&FORMAT=image%2Fpng&DPI=96&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A31468&BBOX=4470654.5050516,5638947.4195052,4471988.6271692,5639432.5548208&WIDTH=1012&HEIGHT=368
both are reasonably fast
>> if I enter the WMS request directly both layers load reasonably fast!?
> Then it is probably not a QGIS issue at all...?
I have no idea where the problem comes from because on my PC (running
OpenSUSE 11.4) both layers are fast in QGIS WebClient
> In any case, sharing the project would help - to look for any anomalies.
what would you need? project and a dbdump? If you are willing to look
into this I would send it to you with a PM.
> Martin
Bernhard
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
