[OSSIM] [Qgis-developer] Re: Fwd: Creating a Python plugin for OSSIM-QGIS
Alex Mandel tech_dev at wildintellect.com
Sat Apr 21 16:49:21 EDT 2012
So you could approach it that way, where every tool you want to expose
has an interface (could be built from templates), look at the QGIS-GRASS
plugin. Or you could approach wrapping it in the new SEXTANTE plugin the
way OTB, SAGA and GRASS are done.
It somewhat depends on what you're trying to expose and what it needs
from QGIS in order to work.
Thanks,
Alex
On 04/21/2012 01:41 PM, Vipul Raheja wrote:
> Hi Alex and Peter,
> Thanks for your replies.
> Sure, I understood the first part of the process regarding the Python path.
> As for the second part, will the plugin writing involve all the Qt stuff
> too? Since you said it would simply import the Python-wrapped library os
> OSSIM, will the plugin need to handle the UI for every OSSIM function also?
> As in, how every functionality of OSSIM will look like and work in QGIS?
> Sorry if it's a noob question, I really have no idea about the plugin
> writing and am trying understand it clearly.
> Kind Regards,
> Vipul
> On Sun, Apr 22, 2012 at 1:39 AM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>> I think the current answer, is that you rely on the user installing
>> OSSIM and the OSSIM pyhon library (eg. on a linux distro python-ossim,
>> prebuilt can be shipped with osgeo4w on windows).
>> That ensure's its on the python path. Then you can write a plugin that
>> simply imports your lib.
>> Thanks,
>> Alex
> For Developers, A Lot Can Happen In A Second.
> Boundary is the first to Know...and Tell You.
> Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
> http://p.sf.net/sfu/Boundary-d2dvs2
> www.ossim.org
> Ossim-developer mailing list
> Ossim-developer at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/ossim-developer
