[Qgis-developer] raster visualization
Andrea Peri
aperi2007 at gmail.com
Wed Apr 25 06:11:23 EDT 2012
>Depending on the number of cells, dealing with > 20 raster files
>requires a totally different approach.
I agree. There are surely more than one approach type to the raster usage
problem.
Surely there is the user that need a thematic map and need a really good
analysys . It need all the statistics to do and so it agree if the qgis to
it by default.
But there is also the user that need a base map for their work. This second
kind of user is principally a vectorial user. An user that work principally
on a vectorial dataset . It need a raster only as base map where apply
their vectorial data. This user tipically is not a power-user for qgis, but
instead it is a power-user for it dataset. It know all of its vectorial
dataset , but instead is a poor user of rasters.
The big difference is that the power-user for thematic raster is able to
understand what it need for raster and so is able to open the porperties of
qgis and set qgis to calculate the statistics. It open properties and set
all he need to have.
The power-user for a vectorial dataset is not always able to understand
what mean usage a raster. So it is not so able to open qgis and remove the
settings that slow the qgis.
This is the main difference I guess should be pointed when plan the
usability of the interface. Think that a user that don't know so well the
raster theory cannot understand why qgis is so slowly to open a raster
rather than other programs so it cannot resolve this slowness. Instead an
user that know the raster theory is able to open qgis and set it to
calculate all it need to know.
Andrea.
2012/4/23 Agustin Lobo <alobolistas at gmail.com>
> Andrea,
> Even for visualization, this is clearly a different problem than the
> common RGB or multi-spectral imagery.
> We cannot deal with 13000 raster layers in the same way as we do with a
> dozen.
> Have you tried rasterlite?
> Agus
> El día 22 de abril de 2012 21:37, aperi2007 <aperi2007 at gmail.com>
> escribió:
> > Hi Agus ,
> > thx for your informations.
> >> Opening the raster layers very fast but getting a bad visualization
> >> would not be a major
> >> waste of time? This is what currently happens to me: the initial
> >> display is always useless.
> > I understand your point of view, but i guess is not a need for every
> users.
> > Same users can't wait the 4+ minutes need for the elaboration of a
> raster.
> > Again because an user could open usually more than 20 rasters for every
> > session, I guess this elaboration should be absolutely optional to avoid
> a
> > really big lost of time.
> >> If your raster layers have similar statistics and or you want to
> >> display them with the same stretching so
> >> that grey levels or colors are comparable (which is often my case
> >> also, with time series of ndvi for example), a common style file would
> >> be the best solution.
> > Your solution seem good to me.
> > We have more set of rasters of ortophoto type colors and grey.
> > Eachset of colors photo is surely with comparable levels, instead I don't
> > know for the gray photo sets.
> > They are too older (1954 and so on).
> > Instead for raster cell (grid data) from Lidar:
> > Just now we begin to merge all our sets to have a full land-cover.
> > So we are merging 1x1, 2x2 and 3x3 meters cells.
> > I don't know if this could have some trouble with having a comparable
> set of
> > values, but guess of no.
> > Surely is not possible to find a unique style good for all the sets, but
> is
> > possible to establish a good style for each set.
> >>...Perhaps, in
> >> case a raster style is present, the by default procedure and
> >> calculations could be bypassed. Would this be a good solution
> >> in your case?
> > You mean a file raster-style in the same folder of the raster set or of
> the
> > catalog file ?
> > I guess this could be a good compromise to help the use in situation like
> > ours.
> > Andrea.
> > Il 22/04/2012 19:43, Agustin Lobo ha scritto:
> >> Andrea,
> >> be the best solution. Perhaps, in
> >> in your case?
> >> Agus
> >> El día 20 de abril de 2012 15:10, Andrea Peri<aperi2007 at gmail.com>
> >> escribió:
> >>>> - on initial load of a raster, generate a quicklook that is the larger
> >>>> of 1/4 screen resolution or 500x500 pixels by sampling every nth pixel
> >>>> - generate a histogram from the quicklook
> >>>> - calculate clipped 2% - 96% range min max for each band
> >>>> - apply a histogram stretch based on the above
> >>>> - the histogram could be used for generating the graph in raster
> >>>> props, and the quicklook could be used to create thumbs and previews
> >>>> etc
> >>>> - ideally we should cache these quicklooks and only regenerate them if
> >>>> the underlying dataset has changed
> >>>> I believe if we do this we will have fast initial load and the images
> >>>> (grayscale and rgb) will 'look right' when first loaded (i.e with good
> >>>> contrast) and it would not be necessary to assign any color value to
> >>>> grayscales by default.
> >>>> Regards
> >>> Hi,
> >>> just my 2 ct.
> >>> I guess the more important capability with raster is to open they
> faster
> >>> possible.
> >>> I fear calculate all these values on first opened take more time than
> >>> what
> >>> is waitable for the open of a raster.
> >>> Perhaps this action should be choosable by settings ?
> >>> Of course I see our situation.
> >>> Our situation is of more sets of raster (7-800 each set) where every
> >>> raster
> >>> is grey level or true color of 3-400 Mbyte each.
> >>> And all these raster are accessible by a remote shared server to our
> >>> users.
> >>> For a total, actually, of about 13.000 rasters.
> >>> I don't understand if this new feature could be really usable in a
> >>> situation
> >>> like our.
> >>> Andrea Peri
> >>> qwerty àèìòù
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120425/6a1e12bd/attachment-0001.html
