[Qgis-developer] Re: GRASS regions
gene
martin.laloux at gmail.com
Fri Apr 27 04:38:15 EDT 2012
Andrea Peri wrote
> I guess the concept of region on grass is limited to only the rasters.
> It was used to limited the portion where the grass raster analysis was
> applied.
> It don't work for vectors.
This is true with pre-existing vector layers, but if you apply a treatment
as r.contour whose result is a vector layer, the result will be strictly
limited to the region
http://osgeo-org.1560.n6.nabble.com/file/n4933275/fullregionok.png
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-regions-tp4931222p4933275.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
