[Qgis-developer] GRASS regions
Patrick S.
patrick_GIS at gmx.ch
Fri Apr 27 08:36:41 EDT 2012
Very helpful: Using the flag "-r" (v.in.ogr -r) will allow you to limit the import of a vector file to the current region.
You thus don't need to clip as postprocess but can do that directly when converting.
@strk: Do you know of projects/options to implement the grass topology inside PostGIS2.0?
> >As I'm having to do with topology in PostGIS I'm very interested in the
> >concept behind GRASS regions. It's interesting that you mention a resolution
> >as I've been thinking for a while that a default resolution could be computed
> >given an extent in that the maximum error double precision floating points can
> >represent depend on the biggest absolute value one may ever want to use.
> >An extent (region) would then give you these upper limits so to be possibly
> >usable to compute a resolution.
> >Is this anything close to what GRASS is using these regions for ?
> >Yeah, I know this is probably not the right list to discuss this, but
> >I'm hoping grass people are also here and can help in harmonizing topologies
> >some more, on a neutral gameboard:)
