[Qgis-developer] SpatialIndex error on qgis-server compiling
Andrea Peri
aperi2007 at gmail.com
Fri Apr 27 16:53:23 EDT 2012
>Second, that link seems way outdated, you should check out
>http://libspatialindex.github.com/ <http://libspatialindex.github.com/> -
if you really want to build it!
Thx, Etienne.
>First, why don't you follow the previous suggestions and install
>libspatialindex-dev ?
because the Linux where I'm running the qgis server is a RedHat AS 64 bit.
Of course I could try the centos version if any, but to avoid some mystic
incompatibility I prefer to recompile.
2012/4/27 Etienne Tourigny <etourigny.dev at gmail.com>
> Andrea -
> http://libspatialindex.github.com/ - if you really want to build it!
> Etienne
> On Fri, Apr 27, 2012 at 5:30 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Thx both,
> > I was not understand the spatialindex was added just now.
> > To add it I will like try to compile the spatialindex from source.
> > So I download it from this link:
> > http://sourceforge.net/projects/spatialindexlib/support
> > To compile it , seem is need also the Tools Library,
> > but it seem not available.
> > Is the sources of tools library available
> > somewhere ?
> > Thx,
> > 2012/4/27 G. Allegri <giohappy at gmail.com>
> >> You need to install libspatialindex.
> >> (On Debian/Ubuntu >apt-get install libspatialindex-dev)
> >> or set SPATIALINDEX_INCLUDE_DIR and SPATIALINDEX_LIBRARY to the right
> >> path.
> >> giohappy
> >> 2012/4/27 Andrea Peri <aperi2007 at gmail.com>
> >>> Hi,
> >>> today I update my qgis-server from trunk,
> >>> but in the cmake phase I see an error:
> >>> > CMake Error: The following variables are used in this project, but
> they
> >>> > are
> >>> > set to NOTFOUND.
> >>> > Please set them or make sure they are set and tested correctly in the
> >>> > CMake
> >>> > files:
> >>> > used as include directory in directory
> >>> > /home/archivio/tomcat/software/qgis/Quantum-GIS/src/core
> >>> > linked by target "qgis_core" in directory
> >>> I use
> >>> with_desktop = off
> >>> with_mapserver = on
> >>> with_binding = off.
> >>> Any hints ?
> >>> Thx,
> >>> Andrea Peri
> >>> qwerty àèìòù
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Andrea Peri
> > qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120427/0dc3f11b/attachment.html
