[Qgis-developer] Best practices to run multiple QGIS versions on same machine
Etienne Tourigny etourigny.dev at gmail.com
Fri Aug 3 06:01:18 PDT 2012
I seem some problems too, particularly rasters don't show properly in
1.8 (no bands are selected), probably because of some settings from
qgis-master.
We might want to change the name of the QGis.conf (say QGis-dev.conf)
in the master version, and revert it before releasing.
Etienne
On Fri, Aug 3, 2012 at 6:39 AM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> Hi,
> I would like to ask, what is the best practice to run two and more
> different QGIS versions on the same machine.
> I have QGIS 1.8 installed from regular Debian packages and QGIS master
> from GIT repository compiled and installed locally to my home folder. As
> time goes on, these versions will differ more and more. I am worried
> about corruption of ~/.config/QuantumGIS/QGIS.conf and other user
> settings files and QT databases when switching between these versions.
> Is there any better way than to make some wrapper script which will
> always change setting files depending on the currently running QGIS
> version ?
> How do You compare some feature across two different versions ?
> Thanks
> Ivan Mincik
> Qgis-developer mailing list
