[Qgis-developer] color ramps improvements
    Etienne Tourigny
    etourigny.dev at gmail.com
    Fri Aug  3 12:39:10 PDT 2012
perhaps you didn't catch the previous discussion on this list (subject
"Raster colours"), or you  didn't read this thread closely. Admittedly the
subject of this thread does not mention cpt-city, but...
This is EXACTLY about using the cpt-city files (although their svg variant)
to make color ramps.
Tomorrow this should be in the linux and windows developpment builds, if
you want to check it out - it is in qgis master git.
Etienne
On Fri, Aug 3, 2012 at 4:29 PM, <pcreso at pcreso.com> wrote:
> How about the ability to import/read/use cpt files from CPT city?
> http://soliton.vm.bytemark.co.uk/pub/cpt-city/
> There is a huge number of cartographic (& other) colour ramps/palettes for
> users to tap into from many authors & packages.
> Providing an easy way for QGIS users to make use of these would be a
> valuable asset.
> Cheers,
> Brent Wood
> --- On *Sat, 8/4/12, Paolo Cavallini <cavallini at faunalia.it>* wrote:
> From: Paolo Cavallini <cavallini at faunalia.it>
> Subject: Re: [Qgis-developer] color ramps improvements
> To: "Etienne Tourigny" <etourigny.dev at gmail.com>
> Cc: "qgis-developer" <qgis-developer at lists.osgeo.org>
> Date: Saturday, August 4, 2012, 3:16 AM
> Il 03/08/2012 16:52, Etienne Tourigny ha scritto:
> > is there an existing infrastructure for this in qgis/qt to do the
> following?
> > 1) download the file
> > 2) unzip - I have added the GDAL funcitons to read zips, but not sure
> > if it's easy to unzip a file.
> quite the same as for plugins: I guess having the same widgets for
> installing plugins, styles, and ramps would be a great plus, both for
> users and for developers.
> > where would you get the metadata from? There is metadata for author,
> > group, but not for each gradient. Do you mean the gradient name?
> yes, name is often descriptive enough - when not, we can probably add tags?
> > Someone would have to step in, select a few and propose them. These
> > would be part of the symbols available by default.
> ok, let's start:
> - at least one DEM
> - one batymetry
> - a red, a green,and a blue scale
> - one "semaphore" (green to red through yellow)
> - two other diverging
> - more?
> Maybe we could make a poll? I'm sure specific sectors have their
> requirements.
> NB: palettes with transparency are not previewed in a meaningful way.
> > I think that this will be easier once Arun's work on symbology
> > grouping and "social styles" is merged.
> agreed - see my other thread on GSoC, who was triggered by this issue.
> > Are you talking about clutter in the style manager or the cpt-city
> > dialog?
> in the style manager: we have now a long list of gradients, and the New
> ramp entry could be easily overlooked.
> > If the latter - In this case you have about 3-4 groups which are
> > duplicated, out of more than 100, so I don't see how it adds to
> > clutter. I thought about removing the ColorBrewer option(as they are
> > available in cpt-city), but it is still relevant because there are
> > fewer options to choose from and it is simpler (and nicer) to work with.
> I think adding only the default ones (see above), and letting the users
> build the others, should be ok.
> > This topic is more related to how the gradient is applied to the
> > raster/vector, so this sort of lies outside of the cpt-city dialog (I
> > think) - unless those classification methods are tied to specific
> > gradients?
> some of them yes. some gradients should be applied on absolute numbers,
> not relatively (e.g. slopes, DEM).
> > Another functionality from 1-band plugin that is missing is the
> > possibility to invert colors and palette. This would be very useful,
> > but should it be inside the style manager or in the vector/raster
> > layer dialogs?
> IMHO, in the layer dialog.
> >> - the raster layer property dialog should be made more clear, and more
> >> homogeneous with that of vectors.
> > I agree - perhaps you can submit a mock-up?
> perhaps someone with better designing skills is more suitable.
> IMHO the default interpolation should be linear, not discrete.
> >> One more: I think the default listing should be by theme, not by author.
> > hmm do you mean the selection view? Because aside from that there is
> > no "theme" grouping yet.
> I mean in the cpt-city color ramp dialog (View is by default switched to
> All by author, should be Selections by theme?)
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org<http://mc/compose?to=Qgis-developer@lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120803/edb60672/attachment.html>
