[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Larry Shaffer
larrys at dakotacarto.com
Fri Aug 3 16:21:46 PDT 2012
Noli,
On Fri, Aug 3, 2012 at 5:02 PM, Noli Sicad <nsicad at gmail.com> wrote:
> How can I incorporate qmake in my system?
> It seems that I can't use qmake in my terminal right now.
This is because the place where qmake is installed with the SDK is not
in your PATH environment variable.
You will need to edit ~/.bash_profile (create if not there yet) and
add the path to the 'bin' you noted to the PATH variable:
export PATH=/path/to/sdk/bin:$PATH
Then, log in to a new Terminal session (e.g. restart Terminal). qmake
will be found and can be used in compiling.
Read 'man bash' for more details on its config files.
I will be available on #qgis channel on irc.freenode.net most of the
day today, if you want more help (nickname of 'dakcarto').
Larry
> See this logs.
> Last login: Sat Aug 4 08:56:51 on ttys004
> Nolis-MacBook-Pro:bin nsicad$ qmake --help
> -bash: qmake: command not found
> Nolis-MacBook-Pro:bin nsicad$ ls
> Designer.app moc qt3to4
> Linguist.app pixeltool.app qttracereplay.app
> QMLViewer.app qcollectiongenerator rcc
> lconvert qdoc3 uic
> lrelease qhelpconverter.app uic3
> lupdate qhelpgenerator xmlpatterns
> macdeployqt qmake xmlpatternsvalidator
> Nolis-MacBook-Pro:bin nsicad$ qmake -help
> Double clicking qmake works.
> Noli
> On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
>> It is stlll not clear to me what to do with QtSDK (i.e. Qt 4.7.4) and
>> XCode 4.x with Command Line Tool for compiling QGIS in Mac OS X.
>> Tim has this wiki - Building QGIS 0.8 with Qt4.x for Ubuntu.
>> https://help.ubuntu.com/community/BuildingQuantumGisPoint8FromSource
>> Can some lighten me how to use QtSDK 4.7.4 for Building QGIS in Mac OS X?
>> Noli
>> On 8/3/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>> As it says, "when using a system SDK". If you just compile for your
>>> current
>>> system, with no SDK options, you don't need to do this.
>>> I suppose this should be removed, since I was aiming for simple current
>>> system builds in the instructions.
>>> On Aug 2, 2012, at 11:44 PM, Noli Sicad wrote:
>>>> My QtSDK for Mac OS X is installed in:
>>>> /Users/nsicad/QtSDK/Desktop/Qt/474/gcc/
>>>> See screenshot attached.
>>>> What i am going to do inorder that qt library, include, etc can be
>>>> founded during compilation?
>>>> This is copied (below) from Building QGIS for Mac OS ...
>>>> Leopard note: Qt includes a couple non-framework libraries in /usr/lib.
>>>> When using a system SDK these libraries will not be found. To fix this
>>>> problem,
>>>> add symlinks to /usr/local:
>>>> sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
>>>> sudo ln -s /usr/lib/libQtCLucene.dylib /usr/local/lib/
>>>> These should then be found automatically. Earlier systems
>>>> may need some help by adding '-L/usr/local/lib' to
>>>> CMAKE_SHARED_LINKER_FLAGS,
>>>> CMAKE_MODULE_LINKER_FLAGS and CMAKE_EXE_LINKER_FLAGS in the cmake build.
>>>> From the above statements what I am going to do with my QtSDK
>>>> installation? What need to copy to /usr/lib or link?
>>>> Thanks.
>>>> Noli
>>>> <Screen Shot 2012-08-03 at 2.23.31 PM.png>
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting,
>>> and all for things that the beasts of the jungle would not deign to
>>> possess
>>> - money to purchase the effeminate pleasures of weaklings. And yet
>>> withal
>>> bound down by silly customs that make them slaves to their unhappy lot
>>> while
>>> firm in the belief that they be the lords of creation enjoying the only
>>> real
>>> pleasures of existence....
>>> - the wisdom of Tarzan
> Qgis-developer mailing list
