[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
John C. Tull jctull at gmail.com
Sat Aug 4 13:42:57 PDT 2012
I think you must have something else going wrong on your system. Perhaps your mixing too many different build systems. I use homebrew and it is fine for me on Mountain Lion. I don't have any more specific information for you, but you might see what 'brew doctor' tells you and take it to the homebrew mailing lists/forum.
Regards,
John
On Aug 3, 2012, at 10:05 PM, Noli Sicad <nsicad at gmail.com> wrote:
> SIP in not building Mountain Lion.
> I use homebrew as well, same problem.
> Nolis-MacBook-Pro:bin nsicad$ brew install sip
> ==> Downloading http://www.riverbankcomputing.co.uk/hg/sip/archive/4.13.3.tar.gz
> ######################################################################## 100.0%
> ==> Patching
> patching file build.py
> Hunk #1 succeeded at 185 (offset 6 lines).
> Hunk #2 succeeded at 198 (offset 6 lines).
> patching file siputils.py
> Hunk #1 succeeded at 1485 (offset 51 lines).
> ==> python build.py prepare
> ==> python configure.py --destdir=/usr/local/Cellar/sip/4.13.3/lib/python2.7/sit
> ==> make install
> cc -c -Os -w -pipe -march=native -Qunused-arguments
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o main.o main.c
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o transform.o
> transform.c
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o gencode.o gencode.c
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o extracts.o extracts.c
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o export.o export.c
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o heap.o heap.c
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o parser.o parser.c
> -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o lexer.o lexer.c
> c++ -L/usr/local/lib -o sip main.o transform.o gencode.o extracts.o
> export.o heap.o parser.o lexer.o
> make[1]: c++: No such file or directory
> make[1]: *** [sip] Error 1
> make: *** [install] Error 2
> ==> Build Environment
> CPU: 8-core 64-bit dunno
> OS X: 10.8-x86_64
> Xcode: 4.5 => /Applications/Xcode45-DP2.app/Contents/Developer
> X11: 2.7.2 @ /opt/X11
> CC: /usr/bin/clang
> CXX: /Applications/Xcode45-DP2.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++
> => /Applications/Xcode45-DP2.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang
> LD: /usr/bin/clang
> CFLAGS: -Os -w -pipe -march=native -Qunused-arguments -mmacosx-version-min=10.8
> CXXFLAGS: -Os -w -pipe -march=native -Qunused-arguments
> CPPFLAGS: -isystem /usr/local/include
> LDFLAGS: -L/usr/local/lib
> MACOSX_DEPLOYMENT_TARGET: 10.8
> MAKEFLAGS: -j8
> Error: Failed executing: make install (sip.rb:41)
> These existing issues may help you:
>    https://github.com/mxcl/homebrew/issues/12388
>    https://github.com/mxcl/homebrew/issues/12491
> Otherwise, this may help you fix or report the issue:
>    https://github.com/mxcl/homebrew/wiki/bug-fixing-checklist
> On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
>> Any suggestion of the better SIP and PyQt version that works with QGIS?
>> Which SIP and PyQt version that works with QGIS?
>> Noli
>> On 8/4/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>>> That's a problem to ask on the PyQt list.
>>> On Aug 3, 2012, at 10:45 PM, Noli Sicad wrote:
>>>> Cmake no problem now.
>>>> Nolis-MacBook-Pro:~ nsicad$ which cmake
>>>> /usr/local/bin/cmake
>>>> Now, I got problem compiling SIP.
>>>> Last login: Sat Aug  4 13:35:51 on ttys005
>>>> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ python2.7
>>>> configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin -e
>>>> /usr/local/include -v /usr/local/share/sip
>>>> This is SIP 4.13.4-snapshot-5775580258b3 for Python 2.7.2 on darwin.
>>>> The SIP code generator will be installed in /usr/local/bin.
>>>> The sip module will be installed in /Library/Python/2.7/site-packages.
>>>> The sip.h header file will be installed in /usr/local/include.
>>>> The default directory to install .sip files in is /usr/local/share/sip.
>>>> The platform/compiler configuration is macx-g++.
>>>> Creating siplib/sip.h...
>>>> Creating siplib/siplib.c...
>>>> Creating siplib/siplib.sbf...
>>>> Creating sipconfig.py...
>>>> Creating top level Makefile...
>>>> Creating sip code generator Makefile...
>>>> Creating sip module Makefile...
>>>> Nolis-MacBook-Pro:sip-4.13.4-snapshot-5775580258b3 nsicad$ make
>>>> make[1]: Nothing to be done for `all'.
>>>> cc -c -pipe -fPIC -Os -w -DNDEBUG -I.
>>>> -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7
>>>> -o siplib.o siplib.c
>>>> -o apiversions.o apiversions.c
>>>> -o descriptors.o descriptors.c
>>>> -o qtlib.o qtlib.c
>>>> -o threads.o threads.c
>>>> -o objmap.o objmap.c
>>>> -o voidptr.o voidptr.c
>>>> c++ -c -pipe -fPIC -Os -w -DNDEBUG -I.
>>>> -o bool.o bool.cpp
>>>> make[1]: *** [bool.o] Error 1
>>>> make: *** [all] Error 2
>>>> Noli
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "Those people who most want to rule people are, ipso-facto, those least
>>> suited to do it."
>>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> Qgis-developer mailing list
