[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad nsicad at gmail.com
Sat Aug 4 19:37:34 PDT 2012
I need to know where "c++" is symbolic link.
/usr/bin/c++
( mine is broken)
Can somebody tell me the results when you double click "c++" in your
system, I am assuming that you install "Command Line Tools" or any dev
tools in your Mac OS X.
Noli
On 8/5/12, Noli Sicad <nsicad at gmail.com> wrote:
> Hi John,
> Try installing SIP.
> brew install sip
> Post result.
> Thanks.
> Noli
> On Sunday, August 5, 2012, John C. Tull wrote:
>> I think you must have something else going wrong on your system. Perhaps
>> your mixing too many different build systems. I use homebrew and it is
>> fine
>> for me on Mountain Lion. I don't have any more specific information for
>> you, but you might see what 'brew doctor' tells you and take it to the
>> homebrew mailing lists/forum.
>> Regards,
>> John
>> On Aug 3, 2012, at 10:05 PM, Noli Sicad <nsicad at gmail.com> wrote:
>> > SIP in not building Mountain Lion.
>> > I use homebrew as well, same problem.
>> > Nolis-MacBook-Pro:bin nsicad$ brew install sip
>> > ==> Downloading
>> http://www.riverbankcomputing.co.uk/hg/sip/archive/4.13.3.tar.gz
>> 100.0%
>> > ==> Patching
>> > patching file build.py
>> > Hunk #1 succeeded at 185 (offset 6 lines).
>> > Hunk #2 succeeded at 198 (offset 6 lines).
>> > patching file siputils.py
>> > Hunk #1 succeeded at 1485 (offset 51 lines).
>> > ==> python build.py prepare
>> > ==> python configure.py
>> --destdir=/usr/local/Cellar/sip/4.13.3/lib/python2.7/sit
>> > ==> make install
>> > cc -c -Os -w -pipe -march=native -Qunused-arguments
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o main.o main.c
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o transform.o
>> > transform.c
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o gencode.o gencode.c
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o extracts.o extracts.c
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o export.o export.c
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o heap.o heap.c
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o parser.o parser.c
>> > -mmacosx-version-min=10.8 -Os -w -DNDEBUG -I. -o lexer.o lexer.c
>> > c++ -L/usr/local/lib -o sip main.o transform.o gencode.o extracts.o
>> > export.o heap.o parser.o lexer.o
>> > make[1]: c++: No such file or directory
>> > make[1]: *** [sip] Error 1
>> > make: *** [install] Error 2
>> > ==> Build Environment
>> > CPU: 8-core 64-bit dunno
>> > OS X: 10.8-x86_64
>> > Xcode: 4.5 => /Applications/Xcode45-DP2.app/Contents/Developer
>> > X11: 2.7.2 @ /opt/X11
>> > CC: /usr/bin/clang
>> > CXX:
>> /Applications/Xcode45-DP2.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++
>> > LD: /usr/bin/clang
>> > CFLAGS: -Os -w -pipe -march=native -Qunused-arguments
>> > CXXFLAGS: -Os -w -pipe -march=native -Qunused-arguments
>> > CPPFLAGS: -isystem /usr/local/include
>> > LDFLAGS: -L/usr/local/lib
>> > MACOSX_DEPLOYMENT_TARGET: 10.8
>> > MAKEFLAGS: -j8
>> > Error: Failed executing: make install (sip.rb:41)
>> > These existing issues may help you:
>> >    https://github.com/mxcl/homebrew/issues/12388
>> >    https://github.com/mxcl/homebrew/issues/12491
>> > Otherwise, this may help you fix or report the issue:
>> >    https://github.com/mxcl/homebrew/wiki/bug-fixing-checklist
>> > On 8/4/12, Noli Sicad <nsicad at gmail.com> wrote:
>> >> Any suggestion of the better SIP and PyQt version that works with
>> >> QGIS?
>> >> Which SIP and PyQt version that works with QGIS?
>> >> Noli
>> >> On 8/4/12, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> >>> That's a problem to ask on the PyQt list.
>> >>> On Aug 3, 2012, at 10:45 PM, Noli Sicad wrote:
>> >>>> Cmake no problem now.
>> >>>> Nolis-MacBook-Pro:~ nsicad$ which cmake
>> >>>> /usr/local/bin/cmake
>> >>>> Now, I got problem compiling SIP.
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org <javascript:;>
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
