[Qgis-developer] Building QGIS in Mac OS X (Mountain Lion i.e. 10.8) with QtSQL support
Noli Sicad
nsicad at gmail.com
Sat Aug 4 21:00:59 PDT 2012
Hi Larry,
On 8/5/12, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi,
> Sorry to top post, but... I have not had any significant problems
> following INSTALL to build master branch on Mt. Lion today. I have
> just updated the Mac notes with some optional info on installing
> ccache, and some cmake options for the external libspatialindex [0]. I
> did not add any specific info about compiling on Mt. Lion to the
> notes.
Thanks for updating the documentation on Building QGIS for Mac OS X.
More tweaks and a bit more details documentation the better.
Now, here is proper logs for building SIP in accordance to the QGIS
Mac OS X needs. I am overdriving my homebrew install of SIP.
I am using the tarball of SIP (i.e. sip-4.13.3) after I fixed the c++ problem.
Last login: Sun Aug 5 12:51:29 on ttys010
Nolis-MacBook-Pro:sip-4.13.3 nsicad$ python2.7 configure.py -d
/Library/Python/2.7/site-packages -b /usr/local/bin -e
/usr/local/include -v /usr/local/share/sip
This is SIP 4.13.3 for Python 2.7.2 on darwin.
The SIP code generator will be installed in /usr/local/bin.
The sip module will be installed in /Library/Python/2.7/site-packages.
The sip.h header file will be installed in /usr/local/include.
The default directory to install .sip files in is /usr/local/share/sip.
The platform/compiler configuration is macx-g++.
Creating siplib/sip.h...
Creating siplib/siplib.c...
Creating siplib/siplib.sbf...
Creating sipconfig.py...
Creating top level Makefile...
Creating sip code generator Makefile...
Creating sip module Makefile...
Nolis-MacBook-Pro:sip-4.13.3 nsicad$ make
c++ -headerpad_max_install_names -o sip main.o transform.o gencode.o
extracts.o export.o heap.o parser.o lexer.o
cc -c -pipe -fPIC -Os -w -DNDEBUG -I.
-I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7
-o siplib.o siplib.c
-o apiversions.o apiversions.c
-o descriptors.o descriptors.c
-o qtlib.o qtlib.c
-o threads.o threads.c
-o objmap.o objmap.c
-o voidptr.o voidptr.c
c++ -c -pipe -fPIC -Os -w -DNDEBUG -I.
-o bool.o bool.cpp
c++ -headerpad_max_install_names -bundle -undefined dynamic_lookup -o
sip.so siplib.o apiversions.o descriptors.o qtlib.o threads.o objmap.o
voidptr.o bool.o
Nolis-MacBook-Pro:sip-4.13.3 nsicad$ sudo make install
dyld: DYLD_ environment variables being ignored because main
executable (/usr/bin/sudo) is setuid or setgid
Password:
Sorry, try again.
Password:
cp -f sip /usr/local/bin/sip
cp -f sip.so /Library/Python/2.7/site-packages/sip.so
cp -f /Users/nsicad/Downloads/sip-4.13.3/siplib/sip.h /usr/local/include/sip.h
cp -f sipconfig.py /Library/Python/2.7/site-packages/sipconfig.py
cp -f /Users/nsicad/Downloads/sip-4.13.3/sipdistutils.py
/Library/Python/2.7/site-packages/sipdistutils.py
As we can see the SIP installed properly for PyQt to use for QGIS.
I just like to document this in the list so other Mac OS X (i.e.
Mountain Lion) users can use in the future including me :-).
Regards,
Noli
